Ok this will probably sound silly to some of you guys but here goes.
I've had a couple four wheel drive vehicles in my life prior to my current project truck. I had an 86 Jeep grand wagoneer with quadra-trac 4wd... You simply moved a little lever on the dash from the 2w to the 4w position - and then, not so obvious, there was a hidden lever under the seat that engaged the 4l. I currently own an isuzu trooper with shift-on-the-fly 4wd. You push a button on the dash to engage 4wd, and then use the floor lever to select hi or low. Both were pretty easy to understand.
Now, I've got a 78 Scout. It has a toggle switch on the dash, twist-n-lock hubs, and a lever for 2h, 4h and 4l... I have the original owner's manual, but it doesn't do a good job of explaining how to engage 4wd. Sure, it discusses how to operate each of these controls but nothing on their correct order. What is the correct sequence of events to go from 2wd to 4wd? Right now, I would guess, engage hubs, flip dash switch, select 4wd option lever... But what happens if you get the steps out of order? For instance, if you are creeping in 4l and flip the dash toggle to "off"? Or try to engage 4h without the switch on? The owner's manual covered none of this. I'm not going to go randomly trying things without knowing if it is possible to damage my truck by doing so.
Lil' help? Thx.
Lil' help? Thx.
