hardknocks
got a set of heads i have had reworked to replace my heads that all the ears where broke off on exhaust manifold mounting tabs. when i removed these heads from the donor engine. some of the rocker arms had shims underneath them. i didnt mic the shims but probably .002 or so. question is how do i get the valve lash correctly when i install these heads. is there a way to measure ? i know the rocker are suppose to be torqued down and are non adjustable. or will the lifters be able to make the difference up
