(62 Scout 80 4cyl)the knocking noise in my flywheel/clutch area now apears to be coming from the bottom end,specifically the rear of the bottom end.I went through all the usual suspects,clutch adj,loose flywheel ect,ect.the noise starts out early unnoticeable and as the engine warms it gets louder,my new rear main seal also seems to have developed a leak(engine is slightly overfilled with oil so it could be that).heres my question,can I drop the crank out of the motor,have it machined .010 under and replace the main and rod bearings without pulling the motor?(I dont have the equipment or help to pull the engine at the moment) my local napa can get the bearings for me (sealed power) and there is a really good guy here in town that does nothing but cranks,mostly for race applications.if you guys have attempted something like this id like to hear about it,im totally unfamiliar with this engine and the knowledge here is invaluable to me.thanx
