Fishwagon
Hello folks,
I have torn down a non-ic 392 I acquired to start a build for my trail-queen Scout traveler.
Any comments would be appreciated. This vehicle will never see cruising speeds.
Some info on the rig first:
1. 14bolt rear/Dana 60 front, both detroit locked, 5.13 gears turning 40" tires
2. Transfercase is a klune underdrive followed by a Dana 300 (stock gear ratios in Dana 300). Dana 300 upgraded with 32 spline outputs. Dana 300 to be replaced by atlas in future.
3. Rebuilt 727 tranny, with B&M shift-kit from iho, Jeep output shaft/tailhousing
4. Current engine is a tired 304
ok, onto the engine to replace the 304:
1. Zero deck block w/ silvolite pistons - anything available to try to get say 9.5 or 10.0 compression? I'm not concerned with running premium fuel as it's only a trail rig. Even if it's possible, is it worth it? I have flat top pistons.
2. Smooth out oil passages
3. Clean up exhaust side of heads - still researching this. Keeping 392 heads....not putting 345's on....my research shows 392 heads breathe better (not saying much when it comes to IH heads I know, but I'll take it), bbc valve springs, 3 angle valve job, mill heads just enough to ensure flatness.
4. Balance rotating assembly
5. Stan's headers
6. Researching any intake manifold cleanup that can be done to enhance torque. Remachine intake if needed to correct as a result of block decking
7. Upgraded ignition
8. Eventually replace carb with FI
question:
1. Camshaft - looking at IHOnly's isky grinds, and am torn between the isky-190125-26 and isky 190170. Thoughts?
This is my first IH engine build, so still reading all threads I can get a hold of, but figured I'd post up also. Will be calling for parts once block goes to shop and it passes crack check and I see what bore I'm going to wind up with.
Comments?
Thanks....and have a great day everyone...
Rich
5. Stan's headers
question:
Comments?
Rich
