345 rebuild-quench, compression, cam:
*my ride: (my first post ever, hope this is ok)
1979 Scout II 345a, 727 trans, 4x4 with 3.54 gears, original 4bbl carter tq, original prestolite idn 4002r, emissions air pump, many oem options including a/c, cruise. Use is mostly for cruise-ins and enter in car shows, but also as a back-up daily driver. Use low/midrange power most often, but once in a while long interstate drives. (my other '79 is my rusty-trusty.)
*background:
I believe the engine is original and never been apart. The heads have never been milled (are 3.445" high/thick) and the bores are std. While the engine had some sudden problems arise requiring a tear-down for inspection, internal cleaning, and correction, it showed little wear and I was tempted to just re-ring it, clean it up and put it back together. However, that would have been marginal, and I would probably be sorry later.
So, I'm having the crank polished, heads redone with new valve springs, and guides machined to accept umbrella seals, etc. I'll be putting in silvolite 7082d.030 (can't get the +.020) w/sealed power rings (moly top) (hastings' warehouse is out of the top moly ring in this size).
*this brings us to my problem:
I wanted to keep this close to stock, and not make it "worse". I am concerned about the interrelationship of
quench (squish),
compression ratio,
and camshaft grind
with my carb, stock timing, etc. And available parts.
*what I have:
when I took it apart, I realized I should have made some measurements first, and stuffed #8 piston back in to see what I have:
piston deck height .040" (maybe .038" since it rocked).
Oem piston compression distance (measured with dial calipers) ~1.897" (note 7082d silvolites are 1.891", so this might make a new deck height without machining of .046"??).
Old embossed steel head gasket compressed ~.026". Gasket hole area is 82.13 cm^2 (to calculate cc's later). New compressed felpro will be ~.040"(?).
The above gave me a oem quench distance of .040"+.026"=.066". (seems kind of large to me for a quench-type chamber.(?))
I cc'd all 8 head chambers, got from 79.0cc to 79.8cc with 79.35cc rms average.
Head chamber hole area is 72.65 cm^2 (to be used for calculating change in cc's when milled).
I also took cam lobe and timing measurements for later comparison to a new one.
*where I'm headed(?):
I'm far from an expert or experienced, here, so I need help to decide what to do.
While the IH advertised cr for the '79 345a engine is 8.28:1, the above calculated volumes gives static cr~8.64:1. (perhaps IH meant dynamic, not static? If so, for marketing I would have used static.) since I had no problems previously with engine pinging with stock timing and a working egr, and sufficient pep for my uses, I would like to make sure I don't generate detonation or other problems with any changes.
I'm aware that keeping quench (squish) distance small is my friend to swirl the air and protect from detonation. To keep quench the same would require decking the block because of the thicker gasket (by .014") and maybe a lower piston height (by .006"?). From other forums here, it seems the expert opinion is to zd (zero deck the piston height).
However, several other things are at play here that concern me. To just get back the apparent oem quench distance of .066", the block would have to be decked .020" (still leaving a piston deck height of .026"). This raises static cr. In addition, my shop says I should have the heads milled--I don't know how much yet but let's say .010". This raises cr even more. My calculations show that the final static cr with decking, milling, and my .030"over bore is 8.893:1.
However, with a higher (static) cr I would think one would now especially want a little better 'quench" (smaller than the .066"). Am I on the right track? Suppose I pick a new quench height of .050". Then the block would have to be decked .036", and then the new static cr would be 9.176:1 (piston deck height .010"). Like chasing one's tail. I feel uncomfortable changing from the orginal that much, since I just wanted a stock or only slightly "better" ride before all this happened.
And to top it all off, I have to select a cam. I was thinking of the sealed power cs415 or clevite 229-1415 and new cht945 lifters. Having measured the cam that was in there, including its .006, .020 and .050 lobe lifts and its timing as best I could, these seem to be kinda' close to stock from what little specs I can find. However, I'm aware my "new" dynamic cr is affected by the previously proposed changes and the cam is part of this equation.
I noted the isky 190156 looks good too, but its spec has a .281" tappet lift for both intake and exhaust, and so would give a higher-than-stock .450" intake lift (rocker ratio 1.6:1), but also a whopping! .478" exhaust lift (rocker 1.7:1). It seems to me this is way too much on a slo-mo emissions (or even not emissions) IH.
What is your take on this? And what block decking and head milling and cam combo makes sense?
Sorry if this is too long of an introduction to my problem, but I thought I'd try to explain what I have and how I'm thinking. Like I said, I'm no expert. Please tell me where I am wrong (or right), or if there is another route entirely. Thanks in advance for your thoughts on this.
*background:
quench (squish),
compression ratio,
and camshaft grind
*what I have:
