We did a compleat engine rebuild on a 1979 345 out of a Scout II. My question is there is vacuum in the valve covers, that if you take the oil filler cap off the engine will die. Also the pcv sucks air in so there is vacuum under the valley pan. I am sure all this vacuum should not be there. Did we forget or missed something during assembly? Other than that engine starts and runs fine.
