266 V8 engine, lots of new parts $500
68SJ
I'm selling the engine from my 1968 International Scout 800. It is a 266 c.I. V8. The engine has approximately 80,000 miles and runs perfect. It doesn't leak or burn oil. The engine is still in my Scout if you want to see it run. I will be removing it this weekend. I am only selling because I upgraded to a new fuel injected engine. $500 includes the engine, carburetor, and accessories.
This would make a perfect upgrade for your 4 cylinder Scout.
Work/upgrades include:
new alternator
new water pump, thermostat, and bypass hose
new power steering pump, with brackets
new coil, cap, rotor, wires, plugs
new brass freeze plugs, even on engine rear.
Block flushed
new valve stem seals
new gaskets: valve covers, oil pan, valley cover, intake manifold, rear main seal, exhaust manifold, carburetor.
I also have the following parts for sale separately:
re-ground flywheel
new pressure plate and release bearing
re-cored radiator with new hoses
2 bell housings, v8 to t18/t19
solid state voltage regulator
new electric fuel pump and pressure regulator
engine mounts
if you are interested in everything, we can work out a deal
I am located in north san jose.
Please see my craigslist ad for pictures:
266 v8 International Scout engine
Thanks,
-ryan
