232 Water Pump
dro363697
I have 1971 800 B with a AMC 232
I need to replace the water pump which if I measure correctly, has a 5 1/4 hub height
All I can find are pumps with a 4 5/8 hub height
Do you go with the latter height and make spacer or do I change the pulley on the crank?
If so what pulley do I need?
Insight will be greatly appreciate!
Great question. Not sure on that one. Might want to try calling our parts department to see if they can source you either a new or rebuilt one. Or we should be able to have your core rebuilt. 530-274-1795
