Re: 1980 Traveler in progress, sort of, parts list
Thought would post up a parts list of sorts for my traveler, what all was purchased to be installed, what May or May not have made it in there yet
here you go, quite a bit of it came from Jeff:
reverse shackle kit
SUA plates front/ rear
front/ rear sway bar kits
long travel shock kit front
bilsteins all the way around
long travel beefy beefy drive front driveshaft
Long rear shackles
6" "offroad" shackle for the reverse setup
5/8 u bolts
hd drag link and tie rod w/ ends
pitman arm
ss long brake lines
roundeyes square headlights
body bushing kit
miscellaneous stuff from Jeff like an egr block off plate, gas pedal bushing, few other things.
All f911 hardware from foremost threaded products.
foremost threaded products-f911 bolts
I compared the cost of grade 8 hardware, the cost to upgrade to f911 was $30 more. When you're spending potentially $250 on friggin' nuts and bolts, what's another $30 bucks?
I got a few things from Mark in lubbock also"
slightly used 33 gal gas tank w/ sender (now I can go 300 miles instead of 170!)
used 80 steering gear
front headlight trim
driver tail cap
some gaskets andd
what not
pass rear patch panel
ac condensor
sidemarker bezels/ lenses/ gaskets
square headlight buckets and associated hardware
windshield washer bottle
other stuff
summit racing - high performance car and truck parts | 800-230-3030
Afe 14x5" open element filter
aluminum overflow tank
edelbrock 1406 4brl carb
edelbrock carb adapter/ kickdown bracket
taylor wires
light racing jounce shocks from phil's inc.
Got some light racing jounce shocks, 1.5" travel
uhmw domed feet
thrd fixed mounts
shock shaft extenders
few oddball things from
mcmaster-carr
Mcmaster carr, push to lock fittings, silicon fuel line, an fittings, some latches, other stuff.
Also
psc motorsports, off-road steering experts
Rebuilt my 80' metric gear box, tapped/ ported/ drilled whatever, steering gear for future ram assist if necessary. For $212. Can't beat that. Dropped it off one morning around 8:30, was readfy at 4:30, incredible.
welcome to agr perfomance, inc.
Bought a power steering pump from these guys. Also here in fort worth. Think I would have gotten more for my money if I had done business with psc on this as well. Got the pump first, then the gear. Agr is not very personnable. Psc is very helpful. Also just has cooler looking stuff
these are the highlights, no gears or traction bs yet as I don't know what size tire I'll be comfortably able to run. Thinking probably something along the lines of a toyo mt, 33x13.5 variety. I like em wide. Either 15" or 17" wheels. We'll see.
Would also like overdrive, TBI, all that stuff, but I want a running traveler first with body panels all the same color and no dents. Od on the backburner for awhile.
One note and I'll shut up, if anyone reads this anyways: all the vendors I have used have been very cooperative and forthcoming. With agr as an exception. IHOnly north, Mark drake, and psc are always there when I call,answer any question that I have, and provide excellent, affordable parts. Phil's, and summit are good, just had a hiccup with them last week though. In tough times like these, I try to shop IH businesses first and give them my business if at all possible, help them out. They've all done right by me. Thanks a bunch!
