My name is steve. Some of you know my Mom and Dad, jim and wanda. I am in morriston, fl. I have a Scout that I would like to sell. It has been mine since 1980 or so. It has been through many modifications and such. It has very few issues. It is $20000. I can take all the pictures you want. It could use a paint job as it is a driven truck. You can see it in full glory by searching google for binder under glass. My number is three 52-8 one 2-0909 here are the basics:
fiberglass body
tilt front end
SSII tailgate, grill and door inserts
SSII top and doors (need new plastic)
392 rebuilt by an engine shop 15000 miles ago
bds 4-71 blower
bds carburetor
bds 3 inch belt drive
bds modified intake
bds aluminum scoop air cleaner
griffen aluminum radiator (not yet installed)
ord headers jet hot coated
valve covers jet hot coated
msd distributor
msd boost timing master computer
msd timing computer
msd 6al ignition
hurst SSII front and rear seats (need recovered)
4 inch lift springs
3 inch longer shackles
shortened traveler driveshaft
727 torque flite with hemi bands and clutches and steel 4 gear planetaries
B&M pro shifter
autometer guages including speedometer, tach with shift light, oil filled oil pressure, fuel pressure, alternator gauge, fuel level, transmission temperature
centerline ht II aluminum wheels
BFG 33x12.50 tires
detroit locker rear end (4.09)
tru track front (4.09)
dual shock mounts
33 gallon fuel cell
Holley blue fuel pump
braided fuel lines
original 1973 mustang flip gas cap
tube bumpers front and rear
fiberglass body
tilt front end
bds 4-71 blower
bds carburetor
bds modified intake
msd distributor
msd timing computer
msd 6al ignition
4 inch lift springs
B&M pro shifter
BFG 33x12.50 tires
dual shock mounts
33 gallon fuel cell
braided fuel lines
