bigjohn
1976 Traveller, CA title, non op, also includes Terra top and bulkhead. Purchased 2 IH to restore but spent all my budget on my 74 so time to clean up the shop. Ran when parked but that was 5 years ago, motor had a bad water pump so all I did was verify it ran and didn't appear to have overheated. 304 2bbl, T18, Dana 20 and 44 axles. Cleaner than most rot wise but I did find rot at cab mounts but less than usual. I believe the rear wheelwell lips have been repaired, but overall clean sheetmetal. Top has some small bubbling all over it but appears very usable. Brakes are shot, included is new brake booster, MC, Calipers, shoes and hardware. Also included is a 4 inch SUA Skyjacker lift kit with shocks, brake lines, heavy duty U bolts and reinforced U bolt plates, new aluminum radiator (import) new water pump, extra 2bbl carb, new bucket seats (aftermarket CJ style) and miscellaneous other pieces. Pickup in Oceano CA, Central coast, definitely not driveable. Apart from a couple small pieces pretty much all there and a great start for a resto.
