1974 Travelall control arm bushing
74travelall
I am rebuilding the front suspension and steering on my 1974 Travelall 100 with the FA-5 front coil spring suspension. The only item I can not locate is the lower control arm bushing. The bolt is a 3/4” diameter, the outside diameter of the bushing is 1.69” and the overall length is around 3.3845”. I have tried IH Parts America, rare parts, and generic poly bushings by size with no luck.
Anybody know where I can buy these or is there an alternative?
Thanks
1975IH200
Thanks
P/N 443322C1. Bushing, Lower Control Arm.
https://oldinternationaltrucks.com/...n/lower-control-arm-bushing-100200-1974-1975/.
74travelall
I ordered the bushings and unfortunately the ones listed for this vehicle did not fit. They looked correct but were a loose fit rather than a press fit. However, Errol in the parts area did some research and found another company that said they had a bushing that would fit. Great customer service when a company spends the time to do a parts search to send you to another company!
The part arrived today and fit perfectly. Even though Rare Parts does not have the part listed in their catalog for this vehicle (I even called them and they spent much time looking) the part came in a Rare Part package. The numbers are as follows:
Rare Parts
Diamond Series
RP16694
16694-2I47A
Control Arm Bushing (5)
Hope this helps somebody else with their 74-75 Travelall or pickup with the FA-5 front coil spring suspension
