D Copsmith
1974 International 200. All there. Needs restoring. In decent shape for age. Motor is out but in one piece. 392 V8 with 4 speed transmission. I bought it from second owner. I had intention of using it as base for the dump bed off another 200 I owned. Instead I sold the dump truck to a friend who will use it on his farm. The previous owner removed the motor to check clutch or something and never put it back in. He said it ran fine when pulled. I actually bought a 1974 Loadstar 1700 from him that I use so I must trust him. You can see from pictures it’s all there - even original rear dump manifolds. No rear bumper. The bed was off and stored on the ground so it’s not that great and probably not usable. Two tone with trim is its original paint scheme with trim all around. All trim is there except one small piece for bed. Has some rust - mostly in rockers and that area; small bit on roof front which seems typical as my dump truck had a lot - this is minor compared to that one. Area around hinges is in great shape - see pic. Dual gas tanks. Would make a great restoration. Very tricked out model for that year. Picture of line ticket included. One of the pictures shows the bed that was on it when I bought it - flatbed - that’s gone. Frame in great shape with minor surface rust. Right rear brake is frozen to drum. Rolls fine otherwise.
$1600 or best offer. Text at 804-305-5223.
Located in Goochland County, Virginia
