1972 1210 345 4spd man
moving and have to sell unfortunately....
Id confidently drive this cross country right now..top end redone last year with 3 angle valve job new seals etc; Gates belts, new hoses, Bilstein shocks and springs "fluffed", new motor /trans mounts, Holley 2 bbl, upgraded to power brakes, brake hardware replaced 4 years ago, massive chromolly drag link, 16" wheels with 275/75/16 tires with lots of tread, new u joints, 10,000 lb hitch with adjustable ball, electric brake controller, gl-4 in tranny and diff, oil changed every 3k, limited slip diff, all electric works, electronic ignition, cylinders are at 130-140 compression, engine pulls 21 lbs of vaccuum steady..
Body has some bumps and bruises which was the next step but very little rust. I did the back end with 1' square tube to carry massive weight and bolted to the frame if you wanted to do your own bed its an easy removal.
truck was briefly in the movie Peppermint and also on the food network....cause thats what really matters lol
asking 7k but open to offers especially from this site!
call/text 786 319 2329
