1971 International 1110 Pickup
Techniix
Hello everybody.
I have a 71 1110 that I've been working on as a project for the past couple weeks. Needs a lot of work. But there are a few things I'm stuck on. First is the ignition switch. See picture below:
This is the ignition switch for the truck. It's dead. I bought a universal 4 terminal replacement, but am having a bit of trouble. As you can see there are a lot more wires here than 4. Do any of you have a wiring diagram for this so I know what goes where? On to the next issue... I also heard that there's a main power relay along with a module that controls the instrument cluster behind the dash (a bit skeptical on this one, it seems a bit complicated for a 70s model truck), but wanted to know if anyone has heard of this or where I'd get a replacement. There are several things not getting power. The instrument cluster is especially important.
Thanks in advance for any help!
Now that you know what you need to properly replace the switch, what diagnostics did you perform to arrive at the conclusion that the switch is dead? I think what you might be referring to in terms of the OIL TEMP & FUEL instruments is a little device called a Constant Voltage Regulator, or CVR for short. It is not a relay. What it does is reduce the battery voltage to an average of about 5 volts, which is what those three gauges require as input power. Full voltage will fry them in short order. If even one of those three gauges is functioning properly, then the CVR is doing it's job. If all three are in-op, then the CVR is a leading suspect, but not the only possible cause.
