1966 4x4 1100a Axle Swap
pplaut
What is the recommended axle swap for this rig? Center pumpkin in the rear, passenger side pumpkin in the front. I want disk brakes all the way around. I would like to go with a new enough axle that I could salvage the ABS from the donor. (has anyone done this?)
Thanks!
~P.
Its possible with chevy axles from what I understand, keep in mind that most axles will be wider than your current setup. There is an open knuckle ih front axle thats the right width for stock stance, and I believe the early 70s chevy puters fit on it. No idea about abs though.
