The socut for sale is a 1962 Scout 80 with the safari fold down front window. The motor just had lots of new things installed, ie: upper & lower rad hoses, water pump & gaskets, valve cover gasket, pushrod coner gasket, carb base gasket, intake man gasket, and rebuild distributor. The Scout has a 4cly 152ci witha 3 speed, twin stick d20 t case, d27 axles f&r and a SOA + 3" for a total of 8" of lift. Comes with 35x12.50x15 tires and dished wheels. With the SOA I also installed all new heavy duty 3/8" u-bolt plates and 5/8" ubolts. You will also need to weld new shock tabs on but they are also suplied also 3/8" heavy duty all suplied from ihonlynorth. I also just installed a full top with all new window glass seals and door seals. The doors I have for it need to be installed due to the privious owner had cut the hinges off to remove them. I purchased a good used set from Jeff @ ihonlynorth in linclon CA that had all the hardware to be installed. There are many other things I can go into if you are interested sofar that are installed on this rig. Overall it is a pretty clean Scout for being a 1962 and needs to be compleated with a little love. This is a project Scout that is why I am only asking $1500.00 obo any questions just ask.
Thanks
rick wallen
Thanks
rick wallen
