Go Back   IH PARTS AMERICA > Classifieds > Parts for sale
Old 05-19-2016, 10:05 AM   #1
'Thunder' Dan Seiler
Member Number: 456
Default Rebuilt 1976 304 for Sale and Misc. Parts
I live in portola, CA (96122), about an hour north of truckee.
Dan 530-249-1182.
- 1976 International 304 v8 engine. I did a mild rebuild on the engine in 2002. At that time the oil pump was rebuilt, installed new seals and gaskets, cylinders were found to be in spec and were honed with new rings installed on the pistons, new crank bearings, and I installed a new isky rv cam shaft and lifters. No valve work or machine work was performed other than some porting and polishing of the heads and intake. Also has an updated Holley 2 barrel carb and a angled carb spacer I fabricated that gives the engine the capability to run at about 40-45 degrees of upward nose pitch. Engine is still in the vehicle so you can see and hear it run before I take it out. The engine runs great, I am just upgrading to a 392. Selling the engine complete, with exception of the distributor, alternator/ac compressor bracket (but I have a standard alternator bracket to replace it). Also comes with a relatively new clutch, resurfaced flywheel, and flowmaster dual exhaust that fits under a Scout II. $750 obo. You can hear a video of it running here: https://www.youtube.com/watch?v=mfhatm6xkzo
- 19 gal stock Scout II fuel tank. Is in good shape. Comes with straps. $25 obo.
'Thunder' Dan Seiler is offline   Reply With Quote
Old 10-24-2016, 08:00 AM   #2
Ruper
Member Number: 989
Default Re: Rebuilt 1976 304 for Sale and Misc. Parts
Squraebore or spreadbore manifold. Have a 345 with spreadbore looking for squarebore. In virginia.
M.Scott Rupe
Proud Owner of:
1966, Scout 800, 196 cu in
1975, Scout II, 345 cu in
Ruper is offline   Reply With Quote
Old 10-24-2016, 08:47 AM   #3
Member Number: 456
Sorry, I forgot to update this posting. I sold the manifold and the console. Thanks.
Old 10-31-2016, 08:27 AM   #4
wagonwheel
Member Number: 5595
So motor is minus manifold now?
wagonwheel is offline   Reply With Quote
Old 10-31-2016, 12:59 PM   #5
Member Number: 456
No, that was a different manifold I had for a 345-392. This engine will still have its manifold and carburetor. The only things this engine will not come with are the dui distributor and wires, and the starter. Pretty much everything else though including the exhaust.
Tags
304, 4bl intake, center console
