Go Back   IH PARTS AMERICA > Tech Forums > Transfer Case Tech
Old 07-28-2015, 11:56 AM   #1
Captainkerber
Captainkerber's Avatar
Member Number: 4003
Default Scout 80 Vibration on initial acceleration
I have a 1962 Scout 80 with a 152
the rear end has been change out to a Dana 44 off a Scout 2
when I let off the clutch to accelerate it vibrates pretty bad.
Looking at the driveshaft you can see it bouncing back and forth when under load. Any ideas.
I don't remember if it started after I rebuilt the transfer case or when I upgraded to the Dana 44. Hopping for some suggestions before I start in on it again.
Captainkerber is offline   Reply With Quote
Old 07-28-2015, 02:43 PM   #2
Scout-It-Out
Scout-It-Out's Avatar
Member Number: 904
Default Re: Scout 80 Vibration on initial acceleration
What I want to know is how you can see the drive shaft while you accelerate? which way is the drive shaft moving? Are your u joints good? My first thought would be a clutch but the drive shaft shouldn't be doing anything but rotating.
~Andy
KJ6IYM
1979 Scout II, 304, 727, 3.73, 31s, Spartan locker rear, Powr-Lok front, Hydraulic Brake Booster, Custom bumpers
Scout-It-Out is offline   Reply With Quote
Old 07-28-2015, 03:33 PM   #3
FDChappie
FDChappie's Avatar
Member Number: 3742
It could also be a bad motor mount.
1974 Scout II 345 T-19
1971 Travelette 392 T-36
Old 07-28-2015, 04:25 PM   #4
Robert Kenney
IHPA Tech Moderator
Robert Kenney's Avatar
Member Number: 543
I guess I would ask if it shudders only while the clutch is slipping like when you take of from a start, and the shudder stops once your moving and you have your foot off the clutch pedal?
If so I would suspect the pressure plate.
If it shudders either way even while rolling, verify your u-joint phasing and angles.
Robert Kenney
Old 07-29-2015, 06:03 AM   #5
ihpartsjeff
Administrator & Owner
ihpartsjeff's Avatar
Member Number: 1
What gear ratio does the Scout II rear axle that you installed have?
IH Parts America - Owner
Binder Books
(530)274-1795
Old 07-30-2015, 06:15 PM   #6
Captainkerber
Member Number: 4003
Ok so a little more information the
gear ratio is 3.54
it is different from the front I do to put it in 4 wheel unless in sand.
The motor mounts and tranmission mounts are new
if I let the clutch out very slowly the shuttering is minimual but that is going to burn the clutch out if I make that a standered practice. It is the worst when I star out up hill and is not noticeable at all when I am at speed even I f I accelerate. I do fell it if I slow down like to go over a speed bump with out putting in the clutch then try to accelerate. Low gear it is not as bad.
I did rebuild the transfer case and am did not have the correct measuring device to check the end play to decide the correct sizing for the shims. Would that cause this sort of shuttering.
And I could see the drive shaft by taking of the pannnel covering the transmission o the Scout 80.
Old 07-30-2015, 08:38 PM   #7
FDChappie
FDChappie's Avatar
Member Number: 3742
Has this been an on going issue or did it suddenly happen?
Old 07-31-2015, 08:41 AM   #8
Scoutboy74's Avatar
Member Number: 453
Does this still have the Dana 18 twin stick case? Your stock rear axle would have been offset to be in better alignment with the d18 rear output. The sii axle is centered, which will be putting your rear shaft in a bit of a bind, but shouldn't be enough to cause this issue. It will wear your u-joints out a lot faster though.
Improper t-case output shaft end play can cause all sorts of issues. Some immediately evident and others not so much until later on. Another possibility is the drive shaft being out of phase. The best way to check the phase is to drop the shaft and set it on a level surface to compare the front and back yoke orientation. They should be in perfect alignment. Even being out of phase by one spline can be a problem. While the rear shaft is out, you can then engage the front axle in 4-hi and go for a test drive to see if the shudder condition is any different running on the front shaft only.
Hooty - '74 SII 4x4 - 392/TF727/D20/3.73 D44's/Spartan FA/Krac-lok RA/33g Fuel
Organ Donor - '72 1210 Reg Cab 2WD - 392/TF727/4.10 RA17/7500# GVW - "Use my body to keep you alive!"
Old 07-31-2015, 08:45 AM   #9
FDChappie
FDChappie's Avatar
Member Number: 3742
Perhaps Jeff should institute an annual prize for the member that comes up with the most obscure answer to a problem. I assume the spline issue would be on the slip yoke?
Old 07-31-2015, 08:54 AM   #10
Scoutboy74's Avatar
Member Number: 453
Originally Posted by fdchappie View Post
perhaps Jeff should institute an annual prize for the member that comes up with the most obscure answer to a problem. I assume the spline issue would be on the slip yoke?
Correct. Most obscure answer. that's a good one. Its a fairly well known issue both on this forum as well as others. Now if I could only find my crayons...
Old 07-31-2015, 11:22 AM   #11
Captainkerber
Member Number: 4003
It has been an ongoing problem I will try to check the drive shaft tomorrow evening. Thanks for the help.
Old 07-31-2015, 06:44 PM   #12
FDChappie
FDChappie's Avatar
Member Number: 3742
Originally Posted by scoutboy74 View Post
correct. Most obscure answer. that's a good one. Its a fairly well known issue both on this forum as well as others. Now if I could only find my crayons...
True your answer is fairly common . Perhaps it would have been better stated best answer to an obscure question. An exclusive tee shirt that says IHPartsAmerica genious.
