#1 |
Member Number: 5230
![]() Went to the local car show this morning, after getting home decided to do something while watching football and start my build thread.
So, after two years of owning the Scout here goes. Bought my 67 800 on labor day weekend in 2012 and after sitting on it for a year and collecting parts I got started on the build about a year ago. I have been taking pictures along the way and will continue to update as the build progresses. Here is the Scout as it was purchased. Had a 304, t-18, Dana 20, Dana 30, Dana 44 tapered axle, bench seat and no rear seat. Last edited by DC67 800; 09-14-2014 at 07:47 AM.. |
#2 |
Member Number: 5230
![]() So the plan for the build was a Chevy 350, 4l60e automatic tranny, Jeep Dana 300, Chevy Dana 44 up front for the flat top knuckles (narrowed for Scout II axles, cut and turn), and Scout II Dana 44 in the rear.
On jack stands in the garage, all running gear stripped except for the axles. Engine, tranny and transfer case fitting. Tucked nicely above the bottom of the frame rails |
#3 |
Member Number: 5230
![]() The suspension is spring over w/ Scout II leaf springs, IHPA reverse shackle.
I won't go into the cut and turn as that info has been covered in great detail by others. Question for all you suspension gurus. Note the length of the cast in spring perch on the GM Dana 44 as compared to the length of the spring perch from IHPA used on the drivers side. Will this difference in length cause the springs to be loaded at different rates? Should the drivers side perch be cut shorter to mach the length of the cast in perch? Once the suspension was at the stage in the pictures the engine, tranny & t case were installed and the suspension loaded with entire vehicle weight to make sure everything was correctly place. |
#4 |
Member Number: 5230
![]() After finishing up with the suspension (finished pictures to come) I moved on to rust repair. Unfortunately the kick panels were rusted out at the door hinge mounts and the inner rocker panels also needed replacing. The rocker panels could have probably been reused but having the body taken down this far I just decided to replace them also. Overall the Scout body was pretty rust free thankfully as just replacing the kick panels and inner and outer rockers really burned me out.
You can see how far gone they were. The hinge mounts themselves were surprisingly still in good shape and reusable. Drilling out of spot welds, a good sharp drill bit worked really well. |
#5 |
Member Number: 5230
![]() Here are the body repairs for the rusted areas. Ended up making my own kick panels and inner rocker panels. IHPA supplied the rocker panels, which fit really well. This was a nice surprise as I have seen several posts on forums where people have had to make adjustments to the aftermarket rockers.
Home made parts, I was able to use the removed parts as patterns. Inner rocker in progress. Kick panel installed with outer panel that supports hinge mount. I ended up deleting the fresh are vents and ducts. Since this will not be a daily driver I figured that in the summer the top will be off most of the time and in the winter a window or wind wing can be cracked when necessary. Passenger side in progress. Rocker panel |
#6 |
Member Number: 5230
![]() With the elimination of the air ducts and the removal of the huge factory heater setup under the hood I needed a heater setup. Ended up getting a summit racing heater for warm air. Now I just needed a location for the install.
Since the summit heater pulls air from the motor that is directly attached to the unit core putting it in the engine bay was out of the question, so I needed to fit it in the cab. After some thought and looking over builds I saw what michael dimock did on his build: http://forums.IHPartsAmerica.com/rea...out-800-a.html. This would give me room for the heater and some extra foot room for passengers. As the heater is a compact unit I was able to fit it behind the dash and still leave room in the engine bay for a battery. Fitting of heater/battery sheet metal. All welded in place. A little extra foot room. Space for new heater box. |
#7 |
Member Number: 5230
![]() Power steering was also on the list of upgrades. Since my 800 was a factory v8 the easiest way to achieve this was with a Scout II steering box. It basically fit in the same location as the manual unit from the factory. Didn't want any issues in the future so the frame was sleeved in all three bolt locations and a 1/4" plate was welded to both the interior, and exterior frame rails.
Box fit nicely and all the angles worked with the steering column. |
#8 |
Member Number: 5230
![]() Haven't updated in a while so here is a little progress:
electric wiper motors, they fit behind the dash but I had to do some work on the defrost duct. Here are some pics of my heater/defrost duct work with my custom dash panel that holds the heater vents. You can see the heater in the glove box opening along with the wiper motor. No room for a glove box, but I will have room in a center consle. |
#9 |
Member Number: 5230
![]() Here is my hi steer setup.
Wagoneer pitman arm from IHPA, dom tube drag link and tie rod with GM tres. |
#10 |
Member Number: 5230
![]() Here is my shock fab.
I used 1-1/2" tubing to line everything up. The tubing allowed bolting the top and bottom brackets so they wouldn't move, then I just clamped them in place. No fussing to keep everything positioned correctly. These are just the standard shock tabs that IHPA sells, I welded the plate to the top to hold them together, it also gave me another welding location to the axle tube. The rear shocks are basically in their stock positions, but the bottom brackets are attached to the axle tube since it is now spring over. |
#11 |
Member Number: 5230
![]() I couldn't resist putting these on since they were sitting in the garage taking up space.
I'll get some more pics soon. I haven't done the best job of taking them as I go along. Damian |
#12 |
Member Number: 5253
![]() Great job. I like the shoes. Looks like its gunna be a beast! Keep up the good work.
1976 IH Scout II-345ci-aka "Brewscout" 1968 Chrysler New Yorker-440ci-This ain't your grannys car! |
#13 | |
Member Number: 5230
![]() Quote:
Thanks for the input. I debated putting 35's on it, but I am glad I went with the 33's instead. It stands a lot taller than I was expecting. It May need a leaf or two removed from the rear spring pack when all is done to level the stance. I have been watching your build and was wondering how that weather pack connector kit worked out for you? I have been wanting to get it for my wiring but been debating whether it was worth the expense. |
#14 | |
Member Number: 5253
![]() Quote:
I like the height. I might settle a bit. I'd run it as is.
#15 |
Member Number: 5230
![]() Here are some pictures of my finished dash panel with the electronic gauge kit. All the panels are aluminum. I welded nuts to the back of the dash for the stainless screws. Makes the panels easy to remove. Still have to wire and install switching, but I thought it turned out pretty nice.
Thread Tools | |
Display Modes | |
