Old 08-23-2018, 04:14 PM   #211
Robert Kenney
IHPA Tech Moderator
Robert Kenney's Avatar
Member Number: 543
Default Re: 1964 Travelall and 1967 Travelette All Wheel Drive's
Now that the brakes are 120%, I am moving on to the drivetrain.
I want to replace all of the engine mounts to stop a rubbing/thumping issue that occurs while leaving from a stop. Also reseal this monster oil leaker.
Let me preface the following with this. I like the temperament of the 304, It has nice low to mid range grunt, and pulls OK at the end of the RPM range. The 2 barrel is intended to take full throttle at low rpm, and not fall on its face. That compromises upper end HP. If you have seen the published factory power curves where the engines are compared with and without dual exhaust, you can see that they respond well to flow improvements in stock trim. I would like to fully tap in to that while not effecting the low end performance one bit.
So I decided to just go through the engine, see what it needs and do it. Not sure if it will be stock, or "slightly" better than stock. Slightly better than stock to me is the smallest Comp or Isky cam that is available or a custom grind, mild compression increase, minor flow bench work, small 4 barrel carb and dual exhaust. Now beyond that I can't be certain what I may desire once the thing is apart in my shop.
Not totally off the table but not in the current plan are:
1) Stroke
2) Bore
3) Lightening the recip masses EG pistons and rods. (both custom units)
On 3 I've already done the leg work with my flailing 152 project.
On to the trans. I am fortunate to have the T34 factory installed in this truck. I've spent many many hours amassing replacement parts and part numbers to freshen it, including synchro clutches and other hard parts. The transfer case will suffer the same fate and get a freshening.
I also think I will tackle the cowl rust while the engine is out.
Stay tuned.
Robert Kenney
Old 01-21-2019, 05:28 PM   #212
Robert Kenney
IHPA Tech Moderator
Member Number: 543
Update good and bad. So the bad first.
Have not touched the 1200C as I said I was going to above. Not out of the question, but it seems like the IH gods have found it in their hearts, and threatened to grant me an other Scout 80 (not new to me and I'll explain later) in a box.................. Well kind of in a box,,,,,,,,,,,,,,,,,,, ok some of it in boxes and on the floor or will be, could be on my floor soon, well some time soon............ I hate not knowing the facts. It's totally up to me to create the facts but things are in the way.
Now to the good,,,,,,,,,, well kind of good.
Before all of this personal public IH exposure, before my 65' CS, I had a fairly low serial number(7000's) 61 Scout 80 that I played with and eventually tore apart in the interest of making it a nice example of a 61 scout 80. I had replaced all of the less than perfect front clip with perfect factory metal, (yes drilled out the spot welds and rosette welded them back in) and accomplished 99% of the body work including long blocking the heavy primer to paintable condition. Rebuilt the T90 and T18, swapped in a tapered axle dana 44 in the rear, and did a very sketchy spring over. I had collected hundreds of spare parts some NOS (when they were cheap).
Then along came the offer of my 65 CS and at a price I couldn't refuse. I only had room for one so I sold off the 61 to a fellow employee for peanuts and that included the spare parts that did not cross over to my 65.
I'm going to start a new post on the 61 so follow the rest of this there. if you are interested.
Long story short, I will need my truck to continue to be active in it's current state for a while and also I need to sell a car that I only purchased as an investment. It is only lacking mounting new Goodyear Blue Streak tires before it is off to the block. Until the 61 is close to completion the 1200c will stay as my primary truck.
Robert Kenney
