Old 07-23-2018, 04:54 AM   #1
chopperroxie
Member Number: 9327
Default Rear disc brake conversion issues
Hey guys, I recently bought a rear disc brake conversion kit from IH Parts and installed it. The instructions were a bit vague but after a few hours of trial and error I got it done. I got a new MC and prop valve in the kit too and I installed them and tightened all the fittings down.
Now, my problem is bleeding. I can't for the the life of me get fluid to the rear at all. I had the rear drum brake working and all so it can't be the lines. Has anyone had this problem?
I read in the instructions about removing the caliper to get all the air out? I haven't done that yet, I was wanting to get some fluid out of the rear caliper bleeders before I did that.
Any advice on this?
Corey
1972 IH Scout II 304 4 speed.
chopperroxie is offline   Reply With Quote
Old 07-23-2018, 06:17 AM   #2
Scoutboy74
Moderator
Scoutboy74's Avatar
Member Number: 453
Default Re: Rear disc brake conversion issues
Did you bench bleed the master? That should be the first step anytime a new master is installed since that's where the fluid originates.
Coal Trickle - '99 Dodge Ram SLT 2500 Q-Cab SWB 4x4 - 5.9L 24V CTD/NV4500/8800# GVWR/12K# winch
Hooty - '74 SII 4x4 - 392/TF727/D20/3.73 D44's/Spartan FA/Krac-lok RA/RC 4" SUA/34x11.5 TSLs/33g Fuel/8K# winch
Lemuel - '72 1210 LWB 4x4 CS - 304/TF727/NP205/RA D60 4.10 - "Pull Lemuel, pull!"
Mongo - '71 1210 LWB 2WD - 345/TF727/RA17 D60 4.10 Krac-lok - "Mongo love candy! Duh, huh, huh!"
Old 07-23-2018, 06:24 AM   #3
chopperroxie
Member Number: 9327
Yes, I bench bled the master.
Thanks for the reply
Old 07-23-2018, 11:20 AM   #4
Winchested
Member Number: 9303
Are you vacuum bleeding them?
Old 07-23-2018, 11:23 AM   #5
chopperroxie
Member Number: 9327
No just regular bleeding with someone else pumping the brakes. I get fluid from the front but nothing from the rears.
Old 07-23-2018, 12:03 PM   #6
Winchested
Member Number: 9303
Pull the line off the prop valve and make sure you're getting fluid past it. Then pull the rear rubber line and make sure you're getting fluid past it.
If the level in your master isn't going down your master isn't bled fully or somewhere past that isn't allowing fluid past.
Old 07-23-2018, 04:06 PM   #7
Robert Kenney
IHPA Tech Moderator
Robert Kenney's Avatar
Member Number: 543
Assuming it is an adjustable rear prop valve, crank the adjuster in 1/2 of its range and try to bleed.
Robert Kenney
ďDon't lift until the fear of death over comes the fear of speed.Ē Author Unknown
Old 07-24-2018, 03:41 AM   #8
chopperroxie
Member Number: 9327
Itís not an adjustable prop valve, so nothing to be done there.
@winchested, Iím going to try doing that tonight and see what I have, thatís a good idea. Thank you.
Old 07-26-2018, 05:39 AM   #9
chopperroxie
Member Number: 9327
So I took the MC off and did a complete re-bleed of it and put it back on. I went through and tightened all the fittings up too. I decided to go with the Motive power bleeder since I couldn't find anyone with a strong enough leg to pump the brakes for me continually.
Well it finally bled and I was able to get the rear brakes working fine.
Thanks so much for all your help.
Corey
Old 07-26-2018, 02:10 PM   #10
Winchested
Member Number: 9303
Great news!
Old 08-30-2018, 06:01 PM   #11
pplaut
Member Number: 9180
I may need one of those power bleeders. Have a 46 CJ-2A I did a conversion on and had trouble bleeding the brakes.
pplaut is offline   Reply With Quote
Old 09-06-2018, 04:23 PM   #12
pplaut
Member Number: 9180
Congratulations on getting this done!
