Old 03-01-2010, 09:53 PM   #1
Danny Phillips
Danny Phillips's Avatar
Member Number: 1682
Default Replacing ignition lock cylinder
I just bought a lock set for my new to me 74 Scout II. Doors and liftgate were easy. How do I change out the ignition lock cylinder thanks, Jeff for the prompt delivery of the lock set.
2015 RAM 2500 Heavy Duty Crew Cab Long Bed Laramie Diesel, 2002 Wildwood 30 ft Fifth Wheel, 1974 Scout II, 345, 727, Dana 20, Dana 30 front w/discs and Dana 44 rear.
Danny Phillips is offline   Reply With Quote
Old 03-01-2010, 10:34 PM   #2
Mark Ashford
Member Number: 1099
Default Re: Replacing ignition lock cylinder
Here's a pictorial I made a few years back for a non-tilt column. Never got around to converting it to a full write-up, but it should help.
If your confused about a step, post up the picture and ask.
Mark's photo galleries :: ignition replacement
Mark Ashford is offline   Reply With Quote
Old 03-01-2010, 11:07 PM   #3
Danny Phillips
Member Number: 1682
Thanks Mark; I wasn't sure if I had to remove the steering wheel. I'm planning on installing an aftermarket sw this summer so that will be a good time to swap switch locks and lube the turn signal cams, Danny
Old 10-06-2018, 06:19 AM   #4
Yellowscout74
Member Number: 9372
Hi Mark.
Do you still have the photos on changing out the ignition lock? The pictures are not there any longer. I know it's been a while for this post but trying to do this today.
Thanks a lot
Yellowscout74 is offline   Reply With Quote
