Old 06-30-2016, 06:18 AM   #1
jtpolitte
Member Number: 8218
Default 71GreenScout
I'm doing a frame off restoration of my Scout. I'm down to the frame. Yahoo! Deciding on frame paint & coating.
Several folks I talk to sandblast the frame with suspension/axles/wheels and tires still on and then paint.
I always figured to take these off and get to the frame only for the best job. Is there any reason why people do not disassemble all the way? (common shortcut?) am I being too particular? Would sand get into places you don't want sand?
Give me some opinions...thanks!
jtpolitte is offline   Reply With Quote
Old 06-30-2016, 08:37 AM   #2
codeman
codeman's Avatar
Member Number: 2424
Default Re: 71GreenScout
I took everything off my frame and blasted it. I etched it with eastwood "afterblast" then primed with nason ful-poxy. It came out great! Then, I taped up most of the holes in the frame and coated the inside with another eastwood product made for that purpose. Just can't remember the name.........
I'm making major mods to mine so the bare frame is the place to start anyway. My $.02 worth!!
codeman is offline   Reply With Quote
Old 06-17-2019, 06:23 AM   #3
jtpolitte
Member Number: 8218
Been awhile, and my build is going well thanks to a lot of help.
I'm at the point for wheels and tires.
I have new body mounts, and a 2" lift. I'm considering 32" tires, and new wheels.
Is there anything special I need to consider with the wheels? Is there standoff required on the wheel or does it matter.
I want to be sure I get the full turning radius of the scout and notice the guy before me had bent up the inner fender with heavy lugged tires and turning sharply.
Any info would be appreciated! Never bought wheels before.
Thanks!
Old 06-17-2019, 06:53 AM   #4
ihpartsjeff
Administrator & Owner
ihpartsjeff's Avatar
Member Number: 1
Whether you get 15x8 or 15x10, make sure they have no more than 3.75" of backspacing. Backspacing in excess of 3.75" will cause the inner sidewall of the tire to rub the tierod ends. Once you buy and install your tires you can adjust the axle turn stops to keep the tire from rubbing the leafsprings at full turn.
Jeff Ismail
IH Parts America - Owner
Binder Books
(530)274-1795
Old 06-20-2019, 10:09 AM   #5
jtpolitte
Member Number: 8218
What rim size came std with 71 Scout 2? 15 inch x ? width.
Old 06-20-2019, 10:29 AM   #6
ihpartsjeff
Member Number: 1
Quote:
Either 6" or 7" with an 8" option. Your Line Set Ticket would say what wheels it came with. From there we cross reference in the parts book to see what width that particular wheel is.
Jeff Ismail
Binder Books
(530)274-1795
Old 06-21-2019, 10:04 AM   #7
jtpolitte
Member Number: 8218
Line setting ticket says:
5 Stud Disc Frt Whls 885209651D
5 stud disc sgl rr whl 925209650
Old 06-21-2019, 10:10 AM   #8
jtpolitte
Member Number: 8218
I'd like to run 32 inch tires on these rims. Is that possible? Any recommendations?
The look I'm going for would be black rims, stock hubcaps (which I have) and 32" tires....bigger than normal to match up with my 2" lift.
Old 06-21-2019, 11:55 AM   #9
ihpartsjeff
Member Number: 1
Those should be 6" wide wheels. Going to be a little narrow for a 11.50 wide tire but might fit a 10.50 wide.
Jeff Ismail
Binder Books
(530)274-1795
Old 07-06-2019, 07:21 AM   #10
jtpolitte
Member Number: 8218
Can anyone tell me if these are the original IH hubcaps for my 71 Scout 2. Ive had them since I bought the scout from a guy in 87.
Now that I'm restoring, before I go to wheels, I wanted to know if these are original.
Old 07-06-2019, 07:24 AM   #11
jtpolitte
Member Number: 8218
If not anyone have a pic of what they would have looked like?
Thanks!
Tim
