Register | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Photo Gallery | IH Store | Home |
Thread Tools | Display Modes |
#1 |
Member Number: 8673
![]() Hello my name is Donnie, and I am a new Scout owner as of 2016. I bought my Scout as a project and going to use as a daily/weekend trail rig. I will be posting in phases of my project. I have completely disassembled my Scout and found more and more rust. Its going to be a about a 90 percent rebuild. I will probably be asking a lot of questions as I go along and any help would be greatly appreciated. I am currently starting the rebuild and have parts coming in weekly. My first step is going to rebuild the axles. I am going to stay with the Dana 44 for now until until I can decide/afford to upgrade them later with a little more research and highly dependent on budget. I like many other have lots of plans with what they want to do to their Scout, but money is a big factor in doing so. So at this point I am going to try and make due with some of the parts I already have, and upgrade at a later time. I will also be replacing the rear body parts from the firewall back minus the doors. This is going to be my lifer vehicle or as long as parts are still available to purchase. I am planning on building my Scout around my desired tire size and will make adjustment on the way. I am sure I will be making a lot as I am new too this. I will have pictures on my profile to view with little descriptions until I can figure out how to upload them to the thread. I had error message trying to upload pictures. Thank you for reading this far and hope to hear good feed back as I continue my project.
Last edited by jrfeatherman; 05-11-2017 at 10:10 PM.. Reason: Switched 1970 to 1979 |
#2 |
Member Number: 8673
![]() If I did this right there should be some photos
#3 |
Member Number: 904
![]() Wow, you've done a lot in 2 posts! Looks good! Can't wait to see what happens next! Where are you located?
What size tires are those? Are you putting fuel injection on it?
~Andy KJ6IYM 1979 Scout II, 304, 727, 3.73, 31s, Spartan locker rear, Powr-Lok front, Hydraulic Brake Booster, Custom bumpers |
#4 | |
Member Number: 8673
![]() Quote:
-Im in Henderson Colorado. -They are 35x12.5x15 Kumho Venture MT with 15x8.5 Bully pro 5Ls I wanted to keep it a carb. A little hesitant on adding more electrical. All I have owned were Audis so I wanted to stray away from it, but doesnt mean I havent considered it. One thing I wanted to do differently is instead of going with a 350 or LS which it looks like those are the most common swaps. I wanted to do a BBC 454. I have only seen one that was in a magazine with a 454 and thought it be a nice to have something somewhat unique. So the engine you see is from a 77 GMC pick up. I have more parts that came in and need to post the pictures. Ill probably start putting back together the axles this weekend. One thing that I havent decided on yet was doing a SOA, I wanted to keep it SUA. So with the Rough Country 4 inch lift, reverse shackle kit, and 6 inch shackles I May have enough clearance for the 35s. I was also going to get the Rough Country add a leaf kit to possible get another inch, plus new body bushings should give me about another inch of lift. Fenders will be cut and a older Chevy or Ford fender flare installed to help with wheel clearance. I have to do a little more searching, but for now thats the plan. I will be upgrading the axles later but not right away. Ill try to take as many pictures as possible to record the build. |
#5 | |
Administrator & Owner
Member Number: 1
![]() Quote:
Jeff Ismail IH Parts America - Owner IH Sierra Fall Rallye Event Coordinator Binder Books CPT - Crawler Proven Technology (530)274-1795 |
#6 | |
Member Number: 8673
![]() Quote:
#7 |
Member Number: 8673
![]() I did a little editing of what I am shooting for and my over all goal is the picture I am attaching
I couldnt think of a name for my project but I think I narrowed it down. Project RAHDAWG RAH is short for OORAH (I served 4 years in the Marine Corps) DAWG...well just completes the name and overall look. Since I couldnt think of a color to do, next best thing is keep it bare with a clear coat and black stripe. Hence RAHDAWG |
#8 |
Member Number: 8673
![]() Received the Rough Country 4" lift kit earlier this week
#9 |
Member Number: 8673
![]() Also got the new 4.56 ring and pinions.
#10 |
Member Number: 8673
![]() 5/13/17 I removed the carrier bearings and pinon bearings, Installed the new ring with new ring bolts
#11 |
Member Number: 8673
![]() 5/13/17 Removed the bearings from the axle shafts. New axle bearing kits for front and rear should be in 5/15/17 and hopefully with the rear disk brake conversion kit. Will post pics once they arrive.
#12 | |
Member Number: 1
![]() Quote:
#13 | |
Moderator
Member Number: 453
![]() Quote:
http://www.IHPartsAmerica.com/store/SL394685C2HD.html .....to your freshened up rear axle assembly. And I'm not just being a shill for IHPA. I've personally experienced the dreaded Scout II rear D44 axle shaft poop out of the housing while in motion. In my case, I knew I had a wheel bearing about to go out and I was just trying to gingerly limp the Scout the last 10 miles home so I could address it. Should have parked it right where I was and fetched a trailer. I didn't make it. I was only going about 20-25 mph when the driver side shaft walked out on me, so I didn't have any catastrophic loss of control or major damage, but it was still a sucky situation. With the new bearings, you shouldn't have any worries for years, but the time to put those heavy duty retention plates on is when you have everything broken down already.
Favorite hobby...Driving Salma Hayek in my Scout ![]() ![]() Coal Trickle - '99 Dodge Ram SLT 2500 Q-Cab SWB 4x4 - 5.9L 24V CTD/NV4500/8800# GVWR/12K# winch Hooty - '74 SII 4x4 - 392/TF727/D20/3.73 D44's/Spartan FA/Krac-lok RA/RC 4" SUA/34x11.5 TSLs/33g Fuel/8K# winch Lemuel - '73 1210 Reg Cab 4x4 Camper Special - 304/TF727/NP205/4.09 FA25 & 4.10 RA16 - "Pull Lemuel, pull!" Mongo - '71 1210 Reg Cab 2WD - 345/TF727/4.10 RA17 - "Mongo love candy! Duh, huh, huh!" |
#14 |
Member Number: 8673
#15 | |
Member Number: 8673
![]() Quote:
Last edited by Scoutboy74; 05-15-2017 at 02:48 PM.. Reason: reference to competing vendor deleted |
Thread Tools | |
Display Modes | |
