Old 11-04-2011, 09:12 AM   #1
ihpartsjeff
Administrator & Owner
ihpartsjeff's Avatar
Member Number: 1
Default Where to BUY a Fuel Injection Kit
IH Parts America is proud to be a reseller of hamilton fuel injection kits.
These throttle body fuel injection or TBI systems are configured for the most economical way to replace that old carburetor. Provides great starts, drivability, and fuel economy.
Hamilton fuel injection uses the highest quality thin wall high temperature wire available today. Their harnesses are built with full protection from the elements using state of the art weatherpak connectors. All harnesses have a very simple 3 wire hook up (battery, ignition and ground) plus efi items , also includes a power and fuel pump relay.
This system includes a complete TBI conversion plus a custom efi distributor for complete fuel and spark control.
Included with every kit is an aldl usb port type data logging cable and data logging program. Makes trouble diagnosis or data logging a breeze.
This is what you will receive with your fuel injection kit:
- custom built efi distributor
- rebuilt TBI unit
- ECM (GM production)
- complete wiring harness
- specially calibrated chip
- adapter plate, gaskets, hardware
- external electric fuel pump with filter
- fuel pump relay
- power relay
- coolant sensor
- map sensor
- o2 sensor
- check engine light indicator
- installation instructions
- aldl data logging cable and data logging program
- tech support
- many miles of low maintenance fuel injection operation
for more information and ordering visit our online store - complete TBI fuel injection system for your IH pickup, Scout, Travelall or even loadstar - IH Parts America
Jeff Ismail
IH Parts America - Owner
Binder Books
(530)274-1795
Old 08-22-2015, 10:20 AM   #2
stinkfinger
Member Number: 7198
Default Re: Where to BUY a Fuel Injection Kit
This kit still exist the ink dosent work
stinkfinger is offline   Reply With Quote
Old 08-22-2015, 10:48 AM   #3
Bill USN-1
F.I. Moderator
Bill USN-1's Avatar
Member Number: 7
Quote:
Originally Posted by stinkfinger View Post
this kit still exist the ink dosent work
Yes it's avail. The link has changed when the name changed.
Thanks,
bill
Bill USN-1
HAMILTON FUEL INJECTION
Learn to do it right.
Old 12-17-2015, 03:58 PM   #4
chucky
Member Number: 8011
Will this kit work on a gen 1 sbc? I currently have an 350 with an edlebrock performer intake and a 600 cfm from your shop.
c
chucky is offline   Reply With Quote
Old 12-19-2015, 11:01 AM   #5
Bill USN-1
F.I. Moderator
Bill USN-1's Avatar
Member Number: 7
I do make kits for all makes of engines including the gen 1 sbc.
Bill USN-1
