Old 07-28-2017, 03:46 PM   #31
Scout-It-Out
Scout-It-Out's Avatar
Member Number: 904
Default Re: scout-it-out '79 scout II
weighed my Scout today, 4800 lbs.
1/2 tank of gas
custom welded bumpers front and rear
10lb co2 tank
large fire extinguisher
tool bag
bottle jack
31" spare tire on steel wheel
~Andy
KJ6IYM
1979 Scout II, 304, 727, 3.73, 31s, Spartan locker rear, Powr-Lok front, Hydraulic Brake Booster, Custom bumpers
Scout-It-Out is offline   Reply With Quote
Old 07-28-2017, 03:54 PM   #32
Scout-It-Out
Member Number: 904
i've had one electric fan for a while now. for some reason i thought there wasn't room for a second one... i was wrong.
in the process of wiring the second fan, i found i didn't like the way the first fan was wired. so i rewired both of them! that ground in the foreground is just for the relays.
~Andy
KJ6IYM
Old 07-28-2017, 07:39 PM   #33
Scooter
Scooter's Avatar
Member Number: 917
Nice. Both fans will help. Also hope you didn't use those POS straps that come with most electric fans that go through the radiator. Many years ago, I personally ended up with a bad radiator because of them. Also had to replace another radiator last year in a friends scout because some other shop used them.
The fleet
72 Scout II = SOLD
Old 07-29-2017, 09:13 AM   #34
Scout-It-Out
Member Number: 904
i did use those special zip tie things one one side of each fan. they are not through the radiator though. they're fastened to the ac condenser. the OE condensers are very sturdy, plus i have a spare, lol. thanks for your concern.
~Andy
KJ6IYM
Old 10-19-2018, 04:57 PM   #35
Scout-It-Out
Member Number: 904
In the process of fixing door hinges for my Scout project, I decided to do the ones on my green Scout. Two of the hinges had broken pins when I bought it so I just replaced them with some spare hinges I had lying around. So I rebuilt the factory green hinges with new pins and grease fittings and installed them today. Best thing about it is, the little friction pads were intact so my door doesn't close on my leg anymore!
~Andy
KJ6IYM
Old 12-02-2018, 07:16 AM   #36
Scout-It-Out
Member Number: 904
Christmas tree/ snow run up East of Chico near Butte Meadows. i was the only scout.
Hey Jeff, I found a new use for that fly swatter you gave us! works great for clearing snow away from the valve stem when you need to air down some more.
~Andy
KJ6IYM
Old 12-18-2018, 01:21 PM   #37
Scout-It-Out
Member Number: 904
So I finally got tired of modifying wiper blades to halfway work on my Scout. I got a couple of wiper arms from the wrecking yard with the new hook Style. Then cut off the last two inches. I then drilled and tapped a hole for 8-32 threads. I modified the little plastic washer for the wider arm. I can now buy wipers at any auto parts store that carries the 13 inch!
~Andy
KJ6IYM
