Go Back   IH PARTS AMERICA > Tech Forums > Ignition Tech
Old 02-18-2019, 07:09 AM   #1
Richard
Member Number: 969
Default Distributor internal weights/spring tension
1977 SII, 4cyl, 1bbl Holley, 4 spd T-19, D20 tc, D44 front and back. Original Holley Disto with a Pertronix module installed. BASIC.
The Scout runs fine, just looking to tweak maybe some better/smoother running efficiency?
Question: I am in the process of pulling the Disto out and "going through it". Re: the little springs that "tension" the timing weights. How loose or firm should they be? mine are just a tad short of loose, meaning that I can move the weights with very little finger pressure.
Should the be "firm"? and/or what would be the correct tension? are there replacements springs available? and do "stiffer" springs help with the timing at high RPM's?
Thanks all,
Richard is offline   Reply With Quote
Old 02-18-2019, 07:17 AM   #2
Richard
Member Number: 969
Default Re: Distributor internal weights/spring tension
while I am at it:
would like to replace the original coil.
1. is the stock coil the same for 4 cyl or 8 cyl?
2. and/or what is the difference?
I do realize that these engines do not crank lots of horse power, just looking to maximize the stock truck. Any particular brands to use (or to stay away from)? Would a higher voltage coil work better, or just stay with stock?
