Old 02-21-2019, 03:57 PM   #1
cearly
Member Number: 943
Default pressure in the radiator
not getting coolant in my oil and no oil in the coolant. Checked the radiator with a block tester and shows no hydro carbon mixed wth the coolant. Do i have cracked head or head gasket on an intake gasket problem. Engine is a fresh overhaul and runs great other than the pressure problem.
cearly is offline   Reply With Quote
Old 02-21-2019, 04:48 PM   #2
Robert Kenney
Super Moderator
Robert Kenney's Avatar
Member Number: 543
Default Re: pressure in the radiator
Unfortunately your post is to vague to allow anyone to help you.
Please elaborate as to what pressure in the radiator is concerning you.
Why do you thing the pressure is an issue? All radiators create internal pressure when hot.
Robert Kenney
Old 02-21-2019, 08:46 PM   #3
cearly
Member Number: 943
my engine is a 345 and can idle it long enough for the thermostat to open and will have pressure to foam the coolant and blow out the top. Can watch the bubbles in the coolant. Doesn't seem to be a problem but have never experienced that kind of pressure in any of my other motors.Have purged the coolant to eliminate trap air pockets.
Old 02-22-2019, 03:34 AM   #4
Winchested
Member Number: 9303
What pressure rad cap are you using? Some are 7 some are 15/16 psi.
All coolant systems create pressure as the coolant heats up. Its physics.
Are you using water or a 50/50 mix of coolant?
Old 02-22-2019, 01:00 PM   #5
Greg R
Member Number: 527
Hey Early, haven't seen or heard from you in a long while. You still truck'in?
Foaming coolant can be bad anti freeze that's either way too old or contaminated; and maybe a really fouled or sludged system. Sometimes anti freeze types can be accidently mixed and boy that makes for problems. I bought a car where the former owner's boyfriend topped it off with DexCool when it still had some of the green stuff in it. What a mess that was to clean up.
Another could be air coming in through a leaky water pump seal. If you can, or by taking it to someone with a pressurizing tool, pressurize the system when cold. Use no more than 12-14 psi. Look for leaks while focusing on and around the water pump spit hole near the pulley shaft. A good UV light can help show up any leaking anti freeze.
Old 02-23-2019, 10:47 AM   #6
cearly
Member Number: 943
Hey Greg thanks for the input. Whenever it quits raining i'll flush the radiator and head to Bi Mart for antifreeze. If that does'not make a difference will just run it.
Retired half a dozen years ago and now work l the fire season and the wine harvest. They get desperate and pay goes up.
Old 02-23-2019, 03:12 PM   #7
Greg R
Member Number: 527
Remember the block plugs and heater circuit. Lots of stuff can still be in those places.
Good to see you're gett'in along. I left work too some years ago. Now it's a project or two for hire and volunteer type work. I remember at the last Binder Bee you were thinking about it. Good Luck!
Old 02-23-2019, 03:28 PM   #8
Scoutboy74
Moderator
Scoutboy74's Avatar
Member Number: 453
Dave, if you don't have one of those cheapo Prestone flush kits already tapped into one of your heater hoses, I can testify that they help the flushing process by allowing you to back flush pressurized water through the system. We should do lunch soon. Catch up on old times.
Old 02-23-2019, 07:29 PM   #9
Greg R
Member Number: 527
Any chance I can barge in on that? It's a 3 hr drive but I sure would like to see y'all
Old 02-23-2019, 07:54 PM   #10
Scoutboy74
Moderator
Scoutboy74's Avatar
Member Number: 453
By all means if'n yer that froggy. We better make a formal plan with date certain in that case.
Old 04-07-2019, 12:01 PM   #11
cearly
Member Number: 943
just happen to be checking old post.Anytime lunch is fine maybe the Jersey Lilly? Dave
Old 04-07-2019, 12:18 PM   #12
Scoutboy74
Moderator
Scoutboy74's Avatar
Member Number: 453
There ya are. One of my fayvoraht greezy spoons. Judge Roy never disappoints.
Old 06-11-2019, 03:54 PM   #13
cearly
Member Number: 943
removed the heads and checked for cracks and found from the intake valve to the spark plug the problem. Next problem is finding heads that aren't cracked. Out of six heads only one is a keeper. Trip to Portland to find a shop that does the repair.
