Old 09-08-2019, 03:13 PM   #61
Scooter
Scooter's Avatar
Member Number: 917
Default Re: 72 Ole Yeller
Size:  71.1 KBName:  20190901_112534.jpg
The fleet
72 Scout II = SOLD
Old 11-17-2019, 08:32 AM   #62
Scooter
Scooter's Avatar
Member Number: 917
Last couple weeks, I managed to do some work on Ole Yeller. Two weeks ago I replaced all 6 bearings, along with new seals and thicker axle shaft mounting plates, for the rear axle. After crunching the numbers stamped on the ring & pinion gears, I have 3.54 gears in the rear. Also realized that I have what appears to be a trash crack lock that is falling apart. Pieces of metal chunks, that hold the clutch pack, was falling out. Not to worried about it just yet, because with my spare rear D-44 housing, I am in the process of building it with an ARB and 4.10 gears.
Also:
11 months after I completed the Shackle reversal kit install, I finally ordered and installed a new front drive shaft last weekend. Turns out that my front axle has more issues than I expected. With my twin sticked transfer case, I shifted into front drive only and went no where. From what I can tell, the left, drivers side, locking hub was not engaging. Sigh, guess that going wheeling is on hold until I get to rebuilding the front axle too
The fleet
72 Scout II = SOLD
