Go Back   IH PARTS AMERICA > IH Parts America Area > IH Parts America Product Questions
Old 05-19-2019, 10:57 AM   #1
Winchested
Member Number: 9303
Default Partsmike Hi Steer kit included in your SOA kit.
Just asking this question as I've been doing some research on steering set ups... well after I have mine installed from your kit . But besides that I'm still curious on this.
Why did you guys choose the Inverted T tie rod/ drag link set up rather than the Dual hole Cross over steering?
Just learning for the future as I may add ram assist and have read on Inverted T set ups that the ram can bind when the tie rod rolls due to the drag link.
Thanks for any info.
Winchested is offline   Reply With Quote
Old 05-20-2019, 06:17 AM   #2
ihpartsjeff
Administrator & Owner
ihpartsjeff's Avatar
Member Number: 1
Default Re: Partsmike Hi Steer kit included in your SOA kit.
Shorter arms! The longer 2 hole arms have a tendency to interfere with the shorter, arched leafsprings of a Scout II so that is the main reason why we go with the inverted Tee set up.
When performing hydro-assist, if the ram is angled in the slightest upward or downward position, it will have a tendency to try and twist the tierod when turning. Having the ram as parallel to the tierod as possible should eliminate that problem.
IH Parts America - Owner
Binder Books
(530)274-1795
Old 05-20-2019, 09:02 AM   #3
Winchested
Member Number: 9303
Thanks so much for the reply Jeff that is exactly what I was looking for!
