Go Back   IH PARTS AMERICA > IH Parts America Area > New Products at IH Parts America
Old 03-22-2018, 05:56 AM   #1
ihpartsjeff
Administrator & Owner
ihpartsjeff's Avatar
Member Number: 1
Default CPT Aluminum Dash Panel for 1966-71 Scout 800, 800A, 800B
CPT- Crawler Proven Technology Aluminum Dash Panel for 1966-71 Scout 800, 800A, 800B
Has a CNC machined radius perimeter for a refined look with percision manufacturing lines.
DA sanded finish makes for easy repairs of any accidental scratches, yet has a utilitarian look to it, just like Scout itself!
Three different panels to choose from.
Blank panel if for you to make a panel as you choose.
Stock configuration panel for those wanting to run the same gauge orientation as stock which has One 3 3/8" hole and Four 2 1/16" holes.
And our 2L3S which means Two large 3 3/8" holes and Three small 2 1/16" holes.
Both our Stock and 2L3S panels have Three 7/16" holes for lights.
Look for our matching glove door to come out next along with complete kits with new gauges and sending units.
Proudly Made in the USA!
Dash Panel Order Link
IH Parts America - Owner
Binder Books
(530)274-1795
Old 08-15-2018, 10:37 AM   #2
ihpartsjeff
Member Number: 1
Default Re: CPT Aluminum Dash Panel for 1966-71 Scout 800, 800A, 800B
We now have available complete gauge panel kits with gauges, sending units and dash lights.
CPT - Crawler Proven Technology Dash Panel Kit with modern Gauges for 1966-71 Scout 800, 800A, 800B
Two different panels to choose from.
Top Panel Includes 120MPH Speedometer, 6000RPM Tachometer, Water Temp, Oil Pressure, Fuel Gauge, Oil Sending Unit, Temp Sending Unit, Dash Lights and Installation Screws.
Bottom Panel Includes 120MPH Speedometer, Water Temp, Oil Pressure, Fuel Gauge, Voltmeter, Oil Sending Unit, Temp Sending Unit, Dash Lights and Installation Screws
Dash panel is made from aluminum and has a CNC machined radius perimeter for a refined look with percision manufacturing lines.
DA sanded finish makes for easy repairs of any accidental scratches, yet has a utilitarian look to it, just like the Scout itself!
Other gauge combination's including diesel specific available upon special request.
Gauges are made by Isspro.
An additional dash light is included with the kit so you can choose between red(parking brake) or blue(hi beam) or drill an additional hole and run both.
NOTE - Combination with Tachometer does have a Volt or Amp gauge. One must install one in a secondary location or add a warning light to the panel.
ASSEMBLY REQUIRED. DOES NOT COME ASSEMBLED AS SHOWN IN PICTURE. WIRING OF GAUGE PANEL REQUIRED. REQUIRES MINOR CUTTING OF FACTORY DASH IN ORDER TO BE INSTALLED.*
Dash Panel Made in USA. Gauges are from overseas.
Retail Price $424.95 and $474.95
PURCHASE LINK
PURCHASE LINK
Binder Books
(530)274-1795
