Old 07-26-2019, 06:32 PM   #1
IHCScout78
Member Number: 743
Default Heated Oxygen Sensor
Is anybody using a heated O2 sensor? How do is it wired and does it matter which one?
I have the Affordable Fuel Injection kit that IH Only used to sell.
I installed Stan's Shorty Headers with ceramic coating. I did not want to mess with the coating, so I put O2 sensor downstream of the ball flange.
Now I get codes 13 (lost connection to oxygen sensor) and 44 (out of range lean) whenever I am at light cruise (level, 40-50 MPH). The check engine light does not stay lit when I get back in throttle, and I have confirmed over a couple weeks of driving and clearing codes that I only get them at light throttle.
I think the O2 sensor is not staying hot enough (600 degrees) at light cruise. I know I do not have the sensor in optimal location, but at this point, heated sensor seems simplest solution.
IHCScout78 is offline   Reply With Quote
Old 01-11-2020, 10:09 AM   #2
Bill USN-1
F.I. Moderator
Bill USN-1's Avatar
Member Number: 7
Default Re: Heated Oxygen Sensor
A 3 wire normally has 2 black wires and a white wire.
The white is the sensor and the other 2 are the heating element.
Doesn't matter which what you wire them.
12v + and - it's just a element so polarity doesn't matter.
Colors of witres may vary but still the same.
2 of one color.
Bill USN-1
HAMILTON FUEL INJECTION
Learn to do it right.
