Old 10-31-2018, 06:04 AM   #1
robeastunder
Member Number: 8101
Default Edelbrock Thunder 1806 on stock 392
I bought a 74 2wd Travelall with a stock 392, it came equipped with a Edelbrock Thunder 1806, has anyone every run this carb on a 392? its running pretty rich and stumbles when you floor it or even at 1/4 throttle it will stumble when stomped, PO claims it was been sitting for quite some time, did a redneck tuneup, plugs, wire, cap and rotor, plugs were showing a very rich running carb, anyway suggestions are appreciated on the next step.
Thanks,
-Rob
robeastunder is offline   Reply With Quote
Old 10-31-2018, 07:44 AM   #2
1975IH200
1975IH200's Avatar
Member Number: 731
Default Re: Edelbrock Thunder 1806 on stock 392
That carb is a square-bore carb.
Does your engine have a square-bore intake manifold?
In '74 & '75 IH put spread-bore Carter Thermo-Quad carbs on the pickups & Travelalls & Scouts.
The 1806 is an AVS (Air Valve Secondary) design. It is very tunable.
The secondary air valve on these almost always need to be adjusted. You need a T15 Torx screwdriver for this. They need to be adjusted to suit the weight of the vehicle. Opening too early causes the 'bog'. A simple adjustment fixes that issue. Mixture needles and springs can be changed to adjust the carb mixture.
Spend a few minutes on the Google Search and you should be able to download the Edelbrock manual for your carb.
Edelbrock sells a tuning parts kit for the carb.
Read the manual and tune the carb to suit your engine/truck and you should be satisfied.
This is assuming the fuel system is clean and you are getting fresh fuel to the carb. You didn't mention if the truck sat unused for a long period of time. If it did, the fuel system may need to be cleaned and flushed. Carb may also need a cleaning/rebuild.
Photos?
Another tip: If you have the spread-bore intake manifold, you must use the proper Adaptor. An "open center" adaptor is not recommended. If you use the wrong adaptor, you will have issues.
Also, stock mechanical fuel pump is adequate for the carb. If you have an electric fuel pump, do not go over 6.5 psi fuel pressure. Mechanical pump puts out around 5.0 to 5.5 psi, which is good for most carbs. No need for electric fuel pump in your situation.
Old 10-31-2018, 08:18 AM   #3
robeastunder
Member Number: 8101
The secondary air valve on these almost always need to be adjusted. You need a T15 Torx screwdriver for this. They need to be adjusted to suit the weight vehicle. Opening to early causes the 'bog'. A simple adjustment fixes that issue. Mixture needles and springs can be changed to adjust the carb mixture.
Edelbrock sells tuning parts for the carb.
Read the manual and turn the carb to suit your engine/truck and you should be satisfied.
Photos?
Another tip: If you have the spread-bore intake manifold, you must use the proper Adaptor. If you use the wrong adaptor, you will have issues.
I will check adapter and get some pics up, fuel system has been cleaned but i have not yet tackled the carb which i am sure probably needs a good cleaning, the AVS adjustment was next on my list, and the PO got rid of the mech pump and installed an inline electric pump so i will check the specs on that. I really appreciate the feedback. On a funny note, the PO had the vac advance plumbed to a random bolt hole so at least I got that sorted to the correct port.
Thanks,
-Rob
Old 10-31-2018, 01:16 PM   #4
1975IH200
1975IH200's Avatar
Member Number: 731
Since your vehicle has an electric fuel pump, installation of an Edelbrock p/n 8190 adjustable fuel pressure regulator may be useful.
Old 11-01-2018, 05:03 AM   #5
robeastunder
Member Number: 8101
It looks like a cheap Edelbrock mini pump, ill get a pic tomorrow, i think there are two models, one that does 1-3 psi and one that is 3-7 psi, so in theory i may be ok, here is a pic of the carb base, looks like an adapter is there of some sort, will dive in more once it stops finally raining in NH.
