Old 09-15-2018, 10:30 AM   #1
int77345
Member Number: 624
Default fan shroud gap ??
scout II 345
does this gap around the edge of the fan shroud effect cooling any?
int77345 is offline   Reply With Quote
Old 09-15-2018, 11:24 AM   #2
1975IH200
1975IH200's Avatar
Member Number: 731
Default Re: fan shroud gap ??
Yes.
Old 09-15-2018, 08:20 PM   #3
Scoutboy74's Avatar
Member Number: 453
To expound, the goal is to draw only cool air through the front of the radiator, not super-heated air from the sides. The other thing that isn't ideal about that extended mounting tab is it places the rear pitch of your fan blades all the way inside the shroud body. The ideal arrangement is to have roughly the rear half of the blade pitch exposed with the front half inside the shroud.
Coal Trickle - '99 Dodge Ram SLT 2500 Q-Cab SWB 4x4 - 5.9L 24V CTD/NV4500/8800# GVWR/12K# winch
Hooty - '74 SII 4x4 - 392/TF727/D20/3.73 D44's/Spartan FA/Krac-lok RA/RC 4" SUA/34x11.5 TSLs/33g Fuel/8K# winch
Lemuel - '73 1210 Reg Cab 4x4 Camper Special - 304/TF727/NP205/4.09 FA25 & 4.10 RA16 - "Pull Lemuel, pull!"
Mongo - '71 1210 Reg Cab 2WD - 345/TF727/4.10 RA17 - "Mongo love candy! Duh, huh, huh!"
Old 09-15-2018, 09:07 PM   #4
int77345
Member Number: 624
Ok.
Are there any idea on how to line up the shroud properly with the 1 inch body lift ?
Old 09-16-2018, 09:57 AM   #5
Scoutboy74's Avatar
Member Number: 453
You can seal the side gaps with whatever material makes sense. That would be the most important thing. You could trim an inch around the circumference of the engine side of the shroud. Some people are naturally hesitant to hack up those shrouds.
Old 09-17-2018, 05:38 AM   #6
int77345
Member Number: 624
scoutboy74,
thank you i will see what i can come up with the make a seal to the radiator.
Old 09-17-2018, 06:03 AM   #7
ihpartsjeff
Administrator & Owner
ihpartsjeff's Avatar
Member Number: 1
I usually buy 3-4" wide foil tape from the local Home Depot, the stuff designed for hot air ducts. Apply to both the shroud and radiator to cover the gap. Can look a tad funky but is very effective in covering up the gap. If you ever need to service the waterpump or whatever, cut the tape, then reapply upon assembly.
IH Parts America - Owner
Binder Books
(530)274-1795
Old 09-18-2018, 05:20 AM   #8
int77345
Member Number: 624
good idea ! thank you !
