Old 09-20-2018, 07:01 AM   #1
Speharboy
Member Number: 9397
Default 1969 Scout 800a w/304
I bought a scout about 2 years ago and it needs a complete rebuild I got the motor running when I first got it but it needs everything. Where do I start and how can i make it cheaper than $6,000. I am thinking I will leave most of the body the way it is rough. I also have complete access to a steel shop. So any help will be great, this is my first rebuild.
Speharboy is offline   Reply With Quote
Old 09-20-2018, 10:24 AM   #2
Scoutboy74's Avatar
Member Number: 453
Default Re: 1969 Scout 800a w/304
That's a really broad question. It might help you to break the rig down into the major systems, ie drive train, running gear, electrical, brakes, steering/suspension, body/trim. Triage each system or group separately and then attack one system at a time. Vehicle control is obviously a top priority. It needs to steer well and stop well. By "well", I mean at least as good as it did when it was new. So, for 1969 standards, we're not talking about awesome or excellent steering and stopping, just adequate or slightly above.
Hooty - '74 SII 4x4 - 392/TF727/D20/3.73 D44's/Spartan FA/Krac-lok RA/33g Fuel
Organ Donor - '72 1210 Reg Cab 2WD - 392/TF727/4.10 RA17/7500# GVW - "Use my body to keep you alive!"
Old 09-20-2018, 11:00 AM   #3
Speharboy
Member Number: 9397
OK sounds good
I will start with taking the body off
