Old 04-11-2018, 02:01 PM   #1
dylancw
Member Number: 9090
Default Adding power steering to C series Travelall
Hi all, I've searched the forums but I'm still confused. I have an 1100C Travelall (leaf spring front end, 4x4) and was wondering if the D-series power steering was a relatively easy fit? I know that late C series is easier...
Or if anyone else here has come up with a good method of adding power steering?
Thanks!
dylancw is offline   Reply With Quote
Old 04-11-2018, 06:57 PM   #2
Robert Kenney
IHPA Tech Moderator
Robert Kenney's Avatar
Member Number: 543
Default Re: Adding power steering to C series Travelall
FYI 1100C is a 1968. The C series had PS available oem. Same box as the early D series 4X4.
Saginaw 708D.
Robert Kenney
Old 04-16-2018, 04:48 PM   #3
dylancw
Member Number: 9090
Ok mistake on my end. Found the build sheet. It's an 1100B with four wheel drive.
Old 04-18-2018, 04:27 AM   #4
kevingweq
Member Number: 7503
What box is in your T-all now ?
If it is a Gemmer manual it has a long non-removeable steering input shaft , I swapped out all the necessaries from a 68 into my 67 T-all ,,, Box, column, frame stiffener,pump, brackets etc.
the grill/radiator support will need to be installed from 68 or modified for clearance along with the inner fender,the frame will need to be drilled (easy)
Not a "bolt in" swap ,just a little time consuming
Check frame carefully for cracks behind steering box , also that area is where your "VIN" number is stamped in frame
kevingweq is offline   Reply With Quote
Old 04-19-2018, 05:56 PM   #5
Robert Kenney
IHPA Tech Moderator
Member Number: 543
Big difference between a 67 and 68. 67 PS had the assist cylinder down on the linkage while 68 saw the upgraded steering box with integral power assist on the steering gear. Just like GM IH changed over to the new Saginaw power steering design.
Many differences in the mounting also.
Robert Kenney
Old 09-17-2018, 07:21 PM   #6
Gunfighter97
Gunfighter97's Avatar
Member Number: 9260
dylancw have you made any progress on this? I have a 65 pickup with early D series power box on it from a PO modification, I will be working in this general area soon of you like I can get you pics of how it fits.
Coming to you from behind enemy lines, in an unmarked barn, somewhere in The Communist West
(Escape planned; currently waiting on a vauge, imprecise, and top secret imaginary countdown clock!)
1965 IH D11004x4 "Sherman"
1946 Dodge Job Rated half ton "Rusty"
1973 Fiat 850 Spider "il Cannoli"
Half of a dead 1958 Apache "Mad D-Max(to be)"
Fight the NFA in the Supreme Court! DTOM!
https://gunowners.org/gun-owners-of-...supreme-court/
Gunfighter97 is offline   Reply With Quote
