Register | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Photo Gallery | IH Store | Home |
Thread Tools | Display Modes |
#16 |
Member Number: 10
![]() Additional insight into the "oiling" issue May be found in this thread:
http://www.forums.IHPartsAmerica.com...r-rockers.html Including pics of the cam journals and other components. And here is another thread that had a happy ending but a bogus diagnosis as to the "o" ring!: http://www.forums.IHPartsAmerica.com...ight-ones.html And another one: http://www.forums.IHPartsAmerica.com...ley-plugs.html And another: http://www.forums.IHPartsAmerica.com...in-issues.html Yet another: http://www.forums.IHPartsAmerica.com...ker-issue.html And another: http://www.forums.IHPartsAmerica.com...pit-holes.html
Are yawl ready??? If not here's some training ya might need to prepare: http://vimeo.com/8149690 |
#17 |
Member Number: 1048
![]() Thanks for all the input guys!
Ok, so with all this info, is it a forgone conclusion that something is wrong and I will have to break down the engine. I ran the motor for 5 minutes @1800 rpm w/no oil coming up into the driver rocker assy. If I have a double sump pan w/a little less than 5 quarts, can that really be the problem? A previous response said that the low oil level wouldn't be a problem because I have oil on the pass. Side rocker assy. All the priming in the world and rotation of the cam shouldn't get oil up in the driver head, right? Spinning the pump w/an 1800 rpm drill gives me 50 lbs at the block where the sending unit goes. Is that pressure within reason or could a blockage cause that pressure value? So the question still remains, to break the motor down or not??? I can try to prime the motor again w/about 7 quarts and rotate the crank in very small increments w/a drill spinning the pump. Thanks. |
#18 |
Member Number: 10
![]() If you ran the rig and had oil on one side but not the other...then there is an issue with oil feed on the #2 cam bearing/cam journal. Continuing to roll the motor over to allow oil feed to the driver side is useless at this point if it won't feed with the motor running!
50 psi oil pressure cold is wonderful, that is not the problem. Neither is oil level in the pan. The lube system here is very simple! And it's easy to understand and follow it out! What I would do at this point is pull the engine and put it onna stand. Do not drain the oil or remove the filter. Remove the plugs but keep 'em in the holes loosely so ya can roll the crank over easily remove the crank hub/balancer and timing cover carefully and ya May be able to re-use the timing cover gasket and pan gasket as is. Do not remove the heads or intake/carb. Remove both rocker shaft assemblies, all pushrods, and lifters, keeping the pushrods and lifters in correct order as removed. The lifters will come up right through the pushrod holes using either a magnet or a lifter puller. Do not remove the cam gear, go through the window in the cam gear and remove the flathead retaining screws from the thrust plate. Then carefully pull the cam out of the block and set aside. Inspect all oil holes in the cam journals, tracing the paths completely to insure there is no debris blocking any hole. Then run the oil pump with the drill motor while looking through the lifter galleries for oil coming from all sixteen oil holes. At the same time, look for oil emerging from the #2 cam bearing oil hole. If no oil from that point, then the blockage is between the main oil gallery feed and the cam bearing saddle. If there is oil at that point, then the blockage is between the cam bearing and the spit hole through the block and head. And of course, inspect the cam bearing and holes in the block for correct alignment. All this May have to be done using a flashlight with a flex head and an inspection mirror.
#19 | |
Super Moderator
Member Number: 543
![]() Quote:
![]() no oil will go to the lifter galleries with out the cam installed.. Verify the oil flow to the #2 cam bearing then slip the cam back in and verify the lifters are getting oil. You will probably need to hold the cam in because the oil pressure behind the rear of the cam will try to push the cam forward and out of the bearing shells.
Robert Kenney “Don't lift until the fear of death over comes the fear of speed.”
![]() Last edited by Robert Kenney; 08-31-2009 at 06:32 AM.. |
#20 | |
Member Number: 10
![]() Quote:
My thought process was to rip it down and do a visual, then go back with the cam inna temporary mode! I just didn't finish that thought! One screw into the thrust plate finger tight will hold the cam back.
#21 |
Member Number: 1048
![]() So...I gave up.
Pulled the motor yesterday and took it back where it was redone. The guy who does the work helped me unload it and said that he primes the pump w/every build. He checks both both heads and checks the pressure. They did charge me for 7 qts back in 2000. I asked to be called before they dig in so I can see for myself what all you guys have probably seen countless times. Maybe I did rotate the cam bearing when I turned it over by hand a few years ago????? Well, I'll let you know. You guys are awesome and if not for you, I'd have torched it by now and bought a Chevy! ![]() until the next problem... |
#22 |
Member Number: 1048
![]() Hope everyone had a nice long weekend.
Got a call from the machine shop last Thursday and it was a "spun" #2 cam bearing. Rotated just enough to completely cover the hole. The motor did sit for 9 years and I did turn it over once several years ago w/some m.m. Oil into the cylinders and I probably did it then. Before I did anything this time I did read "bringing old iron back to life". Not sure how much they're gonna charge me yet but I'm bent over pretty good here I think. Next question; I'm might be able to run this thing for maybe 300-500 miles before winter. Will that be enough to open up any clearances btwn shafts & bearings to keep this from happening in the spring? Should I just start the thing every month or so to keep everything oiled & the lifters full? |
#23 |
Super Moderator
Member Number: 543
![]() Sounds like the bearing was installed clocked so the oil hole was blocked from the git go. In my opinion if the bearing is pressed in it will stay and if it encountered enough friction to turn in the block it would be completely toast. Not likely that it would only slip a few degrees then stop slipping. Ask for the bearing they replaced and if they reinstall the bearing, I suspect it never spun.
Either way a stay over the winter will not be a problem once the engine is oiled and run a few miles. Glad to hear the problem was found.
#24 |
Member Number: 10
![]() Robert's comments are the same as mine, this was a botched cam bearing install from the beginning.
Unless the block's #2 cam bearing bore is way oversize, a new cam bearing will not spin...spun cam bearings are caused by complete lack of oil delivery to the entire cam bearing run...or blocked oil delivery to an individual cam bearing saddle. A "spun" cam bearing and a deteriorated/delaminated cam bearing are two different animals. Two different root causes. The machine shop doing the work now needs to verify the #2 cam bearing saddle id in order to determine if it will hold a replacement bearing. If the id is ok, then the bearing did not spin...and if the bearing had spun due to a lubrication issue, the cam journal would be botched as well. An experienced engine assembly dude will know when knocking in a cam bearing that it's "loose"...and the saddle should have been checked for size before doing any other work on the block, just like checking bore dimensions. Why do machine work on a block that has a cam bearing saddle that is out of spec??? When these motors "dry start" after sitting non-rotated, it wipes out the top layer of bearing material (in some cases it's a babbitt-type layer) due to "stiction", as I explained in that document I wrote. No way in hell it will break loose a properly installed cam bearing...if that was the case, the bearing would have been adhered to the cam journal making it very difficult to remove the cam without first removing the stuck bearing with the cam inside the block! If the cam bearing saddle is oversize, then all the saddles need to be checked...and in most cases, the block could have the saddles properly "re-sized" (oversize) and cam bearings with an appropriate oversize shell can be installed. This is specialty engine/machine shop type parts and service that not all machine shops are willing to take on...they just tell the customer that the block is toast which is pure bs. Any engine that is allowed to sit for a prolonged period non-rotated could develop the "stiction" issue! But...the IH I-4 and sv motors are worse in this regard due to the overall design of the lubrication system. And with today's shit-quality gasoline, fuel system deterioration is just as difficult a situation to contend with. This is not to say there is anything "wrong" with the IH lubrication system...it's just "different" as compared to other manufacturer's products and needs to be treated properly during the entire engine build process. Just start and run the motor on a regular basis, allowing it to fully escalate to operational temperature, that means at least 30 minutes to stabilize. And treat the fuel with stabil marine formula fuel conditioner to help offset the debilitating effects of the alcohol/gasoline blend.
Are yawl ready??? If not here's some training ya might need to prepare: http://vimeo.com/8149690 Last edited by Michael Mayben; 09-08-2009 at 08:04 AM.. |
#25 | |
Member Number: 9729
![]() Quote:
#26 |
Member Number: 453
![]() Cam shaft bearings. Carrier bearings are found either in axle differentials, or as center supports between two long drive shafts.
How do you know you're not getting oil to that bank? What's the history of this engine? Have you had the oil pan off lately? If you suspect top end lubrication issues, you should drain your oil and drop your oil pan to see what might be lurking in there. The presence of grey sludge indicates cam bearing de-lamination. The presence of kibbles and bits that are non-magnetic represent chunks of one or more failed cam bearings. In either case, you wouldn't need to worry about one isolated cam bearing. They would all need attention. At that point the engine should come out for complete disassembly, inspection and determination of proper corrective action ranging from top end overhaul, to full blown rebuild.
Coal Trickle - '99 Dodge Ram SLT 2500 Q-Cab SWB 4x4 - 5.9L 24V CTD/NV4500/8800# GVW/12K# winch Hooty - '74 SII 4x4 - 392/TF727/D20/3.73 D44's/Spartan FA/Powr-lok RA/33g Fuel Lemuel - '73 1210 Reg Cab 4x4 CS - 304/TF727/NP205/4.09 FA25 & 4.10 RA16/6800# GVW - "Pull Lemuel, pull!" Organ Donor - '72 1210 Reg Cab 2WD - seized 392 ![]() Mongo - '71 1210 Reg Cab 2WD - 345/TF727/4.10 RA17/6100# GVW - "Mongo love candy! Duh, huh, huh!" |
#27 | |
Member Number: 9729
![]() Quote:
#28 |
Member Number: 453
![]() Did the builder offer any warranty? If it was a screw up on his end, he should have to make it right.
#29 |
Member Number: 9729
#30 |
Member Number: 9729
Thread Tools | |
Display Modes | |
