Old 04-02-2019, 04:29 PM   #1
IHCScout78
Member Number: 743
Default Bent Tie Rod Ends
I have bent tie rod ends - again. The tie rod is a little tweaked also. I am wondering if that would have happened if the tie rod ends (both) had not bent. I had replaced both tie rod ends a couple years ago because they were both bent.
The drag link is straight. It seems to me that it is pretty skinny and should bend first. It is a little shorter, and connects to the steering arm a little further out, but still...
I should mention that it is a moderately lifted 78 Scout II on 33 in tires. Wheeling hard is a matter of perspective, but I do pretty much everything I can on 33s.
I pretzeled a drag link years ago, but that has not happened in the last decade:-)
I happen to have a spare straight tie rod I could rebuild. Are the threaded ends of some tie rods stronger than others?
IHCScout78 is offline   Reply With Quote
Old 04-02-2019, 07:19 PM   #2
Scoutboy74's Avatar
Member Number: 453
Default Re: Bent Tie Rod Ends
In my experience, when that stuff bends or gets tweaked, it is the direct result of an impact. There really isn't that much stress on those components outside of smacking on rocks or stumps.
Hooty - '74 SII 4x4 - 392/TF727/D20/3.73 D44's/Spartan FA/Krac-lok RA/33g Fuel
Organ Donor - '72 1210 Reg Cab 2WD - seized 392/TF727/7500# GVW - "Use my body to keep you alive!"
Old 04-03-2019, 05:23 AM   #3
IHCScout78
Member Number: 743
It is always possible I hit something; I had to think about that.
Both tie rods ends are bent toward vehicle rear. If I hit something, they would bend the other way. I would also think an impact would be more likely to bend the tie rod than the threads on the tie rod end.
I think the tie rod does see high loads rock crawling; think turning large tires against rocks that don't move.
Old 04-03-2019, 06:35 AM   #4
Scoutboy74's Avatar
Member Number: 453
I suppose so. That's one thing I haven't done much of. Could be the reason why a lot of rock buggies modify to full hydro ram assist steering and go away from the old push-pull design. Your rock crawling could be exerting forces on the system that it wasn't designed to withstand.
