Old 06-30-2019, 03:58 PM   #1
firebolt35
Member Number: 9700
Default FUEL AND AMP GAUGE
Need to know whether the amp gauge is connected to the starting circuit in a 72 international 1310. I started messing with the fuel gauge and the amp gauge is broken to shit now. Now it wont start at all. Wont even turn the headlights on.
firebolt35 is offline   Reply With Quote
Old 06-30-2019, 04:10 PM   #2
1975IH200
1975IH200's Avatar
Member Number: 731
Default Re: FUEL AND AMP GAUGE
Yes, that is the power source for electrical power for the cab, etc.
The control circuit for the starter is fed by that source.
Wether the Ammeter is good or bad, you can fabricate a 6" long piece of #10 gauge wire and use it as a shunt for the ammeter.
Especially if you have installed a higher amp alternator in the truck.
Old 06-30-2019, 04:14 PM   #3
firebolt35
Member Number: 9700
So youre saying I can splice a wire in place of it to make everything work. What wires would I be splicing to make it work? The ammeter is completely destroyed I either need a new one or to bypass it. Also thank you so much for the reply. Also could I just add a different ammeter and would it work???
Old 06-30-2019, 04:28 PM   #4
1975IH200
1975IH200's Avatar
Member Number: 731
For your situation, you could:
1. ...connect the two ammeter wire eyelet terminals together with a small bolt & nut, then tape them with electrical tape to fully insulate the terminals from shorting out on the innards of the instrument panel area.
or
2. ...replace the ammeter with a replacement IH ammeter.
or
3 ...replace the ammeter with an aftermarket ammeter.
optional
...The shunt is recommended for when higher amperage alternators are installed. Won't hurt to add one to the standard amperage alternator/ammeter combo.
Old 06-30-2019, 04:30 PM   #5
firebolt35
Member Number: 9700
I had 3 connections on my ammeter. One white one black and one big blue wire.
Old 06-30-2019, 04:35 PM   #6
1975IH200
1975IH200's Avatar
Member Number: 731
Quote:
1. ...connect the three (3) ammeter wire eyelet terminals together with a small bolt & nut, then tape them with electrical tape to fully insulate the terminals from shorting out on the innards of the instrument panel area.
Old 06-30-2019, 04:44 PM   #7
firebolt35
Member Number: 9700
So I did that and nothing happened at all. I will admit before you suggested that I had a similar idea and connected all three but added a ground wire. When I connected power to the battery it popped my added ground wire. However with just the 3 connected right now I dont get anything.
Old 06-30-2019, 06:14 PM   #8
firebolt35
Member Number: 9700
So i guess you have to connect every single wire that was connected to the fuel AND amp gauge all of the like 8 wires ( I didnt actually count how many) and now it runs again...
Old 06-30-2019, 06:17 PM   #9
Scoutboy74
Moderator
Scoutboy74's Avatar
Member Number: 453
I don't get why you would have added a ground wire to that mix when there was no ground wire to begin with. There's nothing but hot wires there. They need to be insulated from contact with ground as Scott said. You probably blew the fusible link, aka slow blow fuse on the engine side of the firewall right near the bulkhead connector on one of the two 10GA blue wires.
Old 06-30-2019, 06:21 PM   #10
firebolt35
Member Number: 9700
Nah it runs. I originally wasnt going to add another ground wire but I was talking to my dad and he suggested it. At any rate. Like I said. Once i connected ALL of the connectors together it fired back up. Also you have 3 1210'S?
Old 06-30-2019, 06:30 PM   #11
Scoutboy74
Moderator
Scoutboy74's Avatar
Member Number: 453
Ok good. The fuel gauge isn't even associated with the ammeter. They just happen to be in the same cluster housing, but they don't have any wires in common. Totally independent of each other. But yes, all of the wires that were on each of the ammeter terminals do have to be combined if you're going to bypass the ammeter. The gauge was serving as a junction for all of those wires. Not the smartest way to do things, but that's how they did it.
Yes, I do have 3.
Old 06-30-2019, 06:42 PM   #12
firebolt35
Member Number: 9700
Its interesting you say the fuel gauge is separate because I had to connect the wires from the fuel gauge as well as the ammeter to get it to fire up. If I just connected the ammeter wires it wouldnt work.
Old 06-30-2019, 06:50 PM   #13
Scoutboy74
Moderator
Scoutboy74's Avatar
Member Number: 453
There are no loose wires for the fuel gauge. Believe me my young friend, I've got three of these, plus a Scout II, which has the same gauges and much of the same wiring. I've been fiddling around on those gauges for damn near 20 years. I know what I'm talking about here, and Scott will back me up on this. The ammeter gauge has two terminals. A Positive and a Negative. But negative in this case IS NOT a chassis ground. It's just negative polarity. So, when you bypass the ammeter gauge, the group of wires from the POS terminal must be combined with the group of wires from the NEG terminal. And there are a handful of them, eight wires sounds about right. But NONE of them are for the fuel gauge.
Old 06-30-2019, 11:38 PM   #14
1975IH200
1975IH200's Avatar
Member Number: 731
Firebolt35 - you clearly cannot read and follow directions.
I'm just glad you didn't set fire to the house or garage.
Clearly I wasted my time today.
I will not repeat that error.
Good Luck with your truck.
Old 06-30-2019, 11:44 PM   #15
firebolt35
Member Number: 9700
Nah you just didnt have the same set up as my truck and were trying to give me directions as if you did. I hooked up the three wires you said to and it didnt do shit. You were just wrong. No need to be an asshole about it...I figured it out anyway though.
