Old 12-03-2018, 09:47 PM   #181
Ricky B
Member Number: 5277
Default Re: I-4 and SV Engine Non-Oiling Rocker Assembly
Originally Posted by Winchested View Post
Yes you did screw up. You should have matched the gaskets that were in there. The gears should only have .003" hosuing clearance.
Unfortunately the only gasket on this pump when I took her apart was a homemade one. And just one, pump body to the 1/16" steel plate. Looked like Stevie Wonder made it in second grade.
And no gasket at all for the steel plate out to the cast iron cover plate. I've never seen an IHC oil pump like this one before----and no Google results with the casting/IH number on it. Hmmmmm.....
I support gay marriage. As long as both chicks are hot...
Ricky B is offline   Reply With Quote
Old 12-04-2018, 10:46 AM   #182
Ricky B
Member Number: 5277
This is what I'm dealing with.....
