Go Back   IH PARTS AMERICA > Tech Forums > Engine Cooling & Mobile HVAC Tech
Old 06-24-2019, 02:35 PM   #1
darren y
Member Number: 845
Default Cooling issues!
I was on my way to help my brother-n-law out, 60mph on the hwy with really old b-rated swampers tires in my 77 Terra was like driving a wobbly ladder. So after less then 10 miles on the hwy, I turned around & headed back home. About 1/2 way there was an awful racket the varied with engine rpm, (my 1st thought was the u-joint @ the rear of my t-case) I was still moving so I pressed on. Soon I could smell coolant, so I must have lost a hose & my fan blade chewed it up?
Less than 8 miles to home, I went for it! 1st 3 miles all greens then a long red light, one big hill left then 4 miles to go. By the time I reached the top of said hill the temp gauge pegged & I was done as there was another red light. So I pulled to the side & lifted the hood as there was a good breeze to try to cool things down a bit. Upon inspection I lost power steering belt into fan which pulled the steering pump into the fan thus bending the fan & mutilating my radiator.
Almost made it home overheated horribly, hopefully didn’t seize the motor.
Got a tow home from a neighbor.
Time to get a new radiator, fan shroud, & power steering pump!
To many Binders, hit me up for parts....
4-sale?:
Early 60's Metro (it runs/drives/stops!)
Many 60's trucks/t-alls
71 1600 frame
71 1110
73 1500 frame
77 Scout II crawler
72 Scout II frame/tub (lifted/rvrs shackle)
77 IH School Bus
+ several sheds full of IH Parts….
Not 4-sale:
66 Scout 800
(2) Scout II's,
(2) 60's truck/t-alls,
56 S-160 ('Mater project)
71 1600 Loadstar crewcab
775-720-3998
darreny@charter.net
Instagram: @ihaddict
darren y is offline   Reply With Quote
Old 06-24-2019, 02:49 PM   #2
Scoutboy74
Moderator
Scoutboy74's Avatar
Member Number: 453
Default Re: Cooling issues!
What bloody carnage! I know I'll probably come off sounding more like your dad than you'd prefer...and I don't even know the gentleman...but a guy really needs to pull over, shut down and start checking into things. A ride on a rollback is usually always cheaper than replacing an engine. Triple A membership makes it even easier. That's just not something to push unless it's life or death. Hope things work out ok for you.
Old 06-24-2019, 08:31 PM   #3
darren y
Member Number: 845
I have AAA, but I was close to home? (sorta) but I am far from conservative, especially when it comes to my IH's, I really beat the shit out of them, not always in a good way. I guess that's why I have so many parts IH's
So the motor still turns over, fire up briefly just to be sure it would, time to tear it down & inspect it, then hopefully put it all back together, (good time to fix that leaky rear main seal).
So either the power steering belt let go got caught it the fan & the pulled the power steering pump into the fan or the lower cast bracket broke 1st sending the pump into the fan, I tend to think the latter as there was a time that I had a lot trouble lining up several steering pumps but always the same cast bracket?? Anyway the tear down has started...
4-sale?:
71 1600 frame
71 1110
73 1500 frame
77 Scout II crawler
77 IH School Bus
Not 4-sale:
66 Scout 800
(2) Scout II's,
775-720-3998
darreny@charter.net
Old 06-25-2019, 05:47 AM   #4
Scoutboy74
Moderator
Scoutboy74's Avatar
Member Number: 453
Umm hmm. "Close to home" for me if shit's clangin' and bangin' and steam's rollin' out is about a block. I might push it that far...or I might say, it's only a block so I'm just gonna park the fucker and walk. I was brought up not to needlessly flog machinery, but your mileage may vary.
Old 06-26-2019, 09:40 AM   #5
darren y
Member Number: 845
I have no morals or values, basically DGAF, but that's a subject for somewhere else….,
Being that I should tear down & inspect this 345, it needs a rear main seal & I want to pop the freeze plugs & clean all the water passages.
So back to the point I might as well drop in a fresh 392 in the meantime, also SOA on full width axles.
4-sale?:
71 1600 frame
71 1110
73 1500 frame
77 Scout II crawler
77 IH School Bus
Not 4-sale:
66 Scout 800
(2) Scout II's,
775-720-3998
darreny@charter.net
