Old 03-13-2017, 10:37 AM   #1
jchazen
jchazen's Avatar
Member Number: 5841
Default ECM fuse keeps popping
Why would my ECM fuse blow? I mean I understand there must be a short but not sure where to start looking lol..any help would be appropriated
jchazen is offline   Reply With Quote
Old 03-13-2017, 01:13 PM   #2
Bill USN-1
F.I. Moderator
Bill USN-1's Avatar
Member Number: 7
Default Re: ECM fuse keeps popping
Are there any error codes?
Have you checked the pins on the back of the ECM?
Bent, dirty?
If you swapped the chip recently, are there any bent pins on it?
Harness chaffing?
You can send me the ECM to test.
Bill USN-1
HAMILTON FUEL INJECTION
Learn to do it right.
Old 03-13-2017, 02:24 PM   #3
jchazen
jchazen's Avatar
Member Number: 5841
Trying to track down a laptop with a cd-rom drive so I can check codes...I might have to sent it to you..unless I can take the ECM to Jeff and he can check it?
Old 03-13-2017, 02:54 PM   #4
ihpartsjeff
Administrator & Owner
ihpartsjeff's Avatar
Member Number: 1
Feel free to bring the whole Scout by josh so that we can double check our installation and make sure a wire hasn't rubbed thru. We can also check for codes at the same time. Please call me ahead of time to make an appointment when you would like to bring in the Scout.
Jeff Ismail
IH Parts America - Owner
Binder Books
(530)274-1795
Old 03-13-2017, 03:44 PM   #5
Bill USN-1
F.I. Moderator
Bill USN-1's Avatar
Member Number: 7
You don't need a laptop for codes.
Just put a wire or paper clip in pins a and b of the diagnostic connector and then turn the key on.
The light will blink.
Count the blinks and look up in the manuals provided with the kit.
Right now without the jumper, the light should come on when you turn the key on and then go off as soon as you start the engine.
Bill USN-1
Old 03-13-2017, 05:48 PM   #6
jchazen
jchazen's Avatar
Member Number: 5841
Ok I'll check codes tomorrow & thanks Jeff, if I can't figure it out I'll call you!
Old 03-15-2017, 12:11 PM   #7
jchazen
jchazen's Avatar
Member Number: 5841
Tried the paper clip and no light came on...
Old 03-15-2017, 02:08 PM   #8
Bill USN-1
F.I. Moderator
Bill USN-1's Avatar
Member Number: 7
It would be much more efficient if you called.
Bill USN-1
Old 03-16-2017, 02:28 PM   #9
jchazen
jchazen's Avatar
Member Number: 5841
Hey bill just dropped it in the mail, you should get it early next week...thanks again
josh
Old 03-21-2017, 09:05 AM   #10
jchazen
jchazen's Avatar
Member Number: 5841
Hey bill just checking to see if you got the ECM ...thanks
Old 03-22-2017, 04:17 PM   #11
Bill USN-1
F.I. Moderator
Bill USN-1's Avatar
Member Number: 7
Tracking says it will be there tomorrow.
Looked up your order, it was May of 2014.
Bill USN-1
Old 03-22-2017, 04:48 PM   #12
jchazen
jchazen's Avatar
Member Number: 5841
Quote:
Originally Posted by bill usn-1 View Post
tracking says it will be there tomorrow.
Yeah it was originally for my 75 with a 304 never installed...bought a 73 with a 345 from Jeff gave him the unopened box and they installed it last May...thanks again
josh
Old 03-23-2017, 06:58 AM   #13
ihpartsjeff
Member Number: 1
Quote:
Originally Posted by jchazen View Post
yeah it was originally for my 75 with a 304 never installed...bought a 73 with a 345 from Jeff gave him the unopened box and they installed it last May...thanks again
josh
And I can vouch for that. Kit was brand new in the box. Not sure if you remember bill but I had you burn us a new chip to work with the 345 and I think swap us out on the TBI adapter.
Jeff Ismail
Binder Books
(530)274-1795
