Old 06-10-2013, 05:44 PM   #1
jasondart
Member Number: 5474
Default Push rod clearance in intake manifold
Engine is put back together, but I have noticed a few things. Here she is thus far.
My question is what should the clearance be for the push rods and the intake manifold hole? It seems too close to the edge. Also, I was not impressed with the stainless steel bolt kit I ordered. They stick out way too much into the hole as you can see in the picture. Every bolt was the same length.
Is this normal for push rod clearance?
jasondart is offline   Reply With Quote
Old 06-11-2013, 05:47 AM   #2
Robert Kenney
Super Moderator
Robert Kenney's Avatar
Member Number: 543
Default Re: Push rod clearance in intake manifold
Yeah that in normal on these engines.. I had polished areas on my factory 152 when I took it apart. I scooted the stands around to maximize clearance at assembly. No more rubbing.
As for the blolts sticking out into the pushrod passage, if they don't create an interference problem, what is the issue?
Robert Kenney
Old 06-11-2013, 07:42 PM   #3
1975IH200
1975IH200's Avatar
Member Number: 731
Quote:
Originally Posted by jasondart View Post
engine is put back together, but I have noticed a few things. Here she is thus far.
Per the IH manual, the bolts in those eight positions (four per side) should be 3/8" nc x 1".
The others should be 3/8" nc x 1 1/4 (four each) and 3/8" nc x 1 1/2" (four each).
Each bolt should have one 3/8" flat steel washer under the head.
