Old 08-04-2019, 07:13 PM   #1
mbiver
Member Number: 9359
Default Compression difference in a 345?
Just did a compression test on my 345 and was wondering if I have too big of a difference between the cylinders or if any of the numbers indicate serious wear/damage? It was the first time Ive ever done one so when I did the dry test I didnt crank it long enough to get max pressure. Just for 1 second. The numbers below are for the wet test where I did a couple of squirts of 10-30 with an oil can directly into the spark plug hole, then screwed in the compression gauge and cranked it for about 4-5 seconds to get max pressure. Any thoughts appreciated and thank you!
Cylinder#/Pressure
1 - 132
2 - 134
3 - 145
4 - 140
5 - 135
6 - 129
7 - 132
8 - 135
1978 Scout II with 1977 345 engine
Four wheel drive Dana 44 Axle's, Dana 20 T-Case, Power Steering, Power Brakes (Disc/Drum), no A/C.
Manual trans, Borg Warner 3-speed w/floor shift.
Prestolite distributor with petronix.
Fuel System: New 19Gal. Poly tank/Sending unit from IHPartsAmerica, Nylon fuel line, relined original fuel neck filler tube, rebuilt Holley 2245 Carb.
Unknown non-oem modifications
mbiver is offline   Reply With Quote
Old 08-04-2019, 09:04 PM   #2
Scoutboy74
Moderator
Scoutboy74's Avatar
Member Number: 453
Default Re: Compression difference in a 345?
Were all the spark plugs out? Was the throttle blocked open? Those numbers are consistent. There's only a 16 psi difference between the highest and the lowest.
Old 08-04-2019, 10:42 PM   #3
mbiver
Member Number: 9359
All spark plugs were out for all tests. Was I supposed to put something on the accelerator to open the throttle during the tests? Like I said, it was the first compression test Ive ever done, so kinda learning as I went. Thanks again.
Old 08-05-2019, 05:17 AM   #4
Scoutboy74
Moderator
Scoutboy74's Avatar
Member Number: 453
Yes, or wedge the linkage wide open at the carb. You want air to be drawn into the engine unobstructed. Is the engine able to be started and ran? If so, it would be e best to warm it up first, then pull all the plugs and do the test to a warm, lubed engine.
Old 08-05-2019, 05:46 AM   #5
mbiver
Member Number: 9359
Still has a slight hiccup that Im trying to diagnose, but it definitely runs. Will be getting a new 2300 carburetor soon that I hope will help narrow things down. So do I need to disconnect the fuel line when performing the compression test with something holding down on the accelerator? Thanks.
Old 08-05-2019, 05:57 AM   #6
Scoutboy74
Moderator
Scoutboy74's Avatar
Member Number: 453
No, just don't cycle it a bunch of times. One squirt won't hurt.
Old 08-05-2019, 10:02 AM   #7
Robert Kenney
Super Moderator
Robert Kenney's Avatar
Member Number: 543
Don't disconnect the fuel line for a compression test.
Robert Kenney
Don't lift until the fear of death over comes the fear of speed. Author Unknown
