Go Back   IH PARTS AMERICA > Tech Forums > Brake Tech
Old 11-14-2017, 09:51 AM   #1
Draayer
Member Number: 8981
Default Swapping 78 disk brakes to 71 scout two
I have a 71 Scout two and bought a 78 parts scout for the disk brakes. I don't want to swap axles because I would rather have the gearing of the 71 so I'm just swapping the disks for the drums. I took the hub off, bearings, brakes etc off of both scouts but the 78 has an 8 bolt pattern and the 71 has a 6 bolt pattern (the part that holds the drum or disk brakes on to the axle). I was told they would swap but it's not looking that way. My question is this, can I swap the entire steering knuckle? Remove the tie rods, etc and swap the entire unit?
Thanks,
Draayer is offline   Reply With Quote
Old 11-14-2017, 10:51 AM   #2
FDChappie
FDChappie's Avatar
Member Number: 3742
Default Re: Swapping 78 disk brakes to 71 scout two
It doesn't sound like you've got a Scout axle in the 78. The 71 will have a D30, the 78 (if that's what it is) will have a D44 which is a stronger axle. Looks like the best option might be to regear the 78 axle.
1974 Scout II 345 T-19
1971 Travelette 392 T-36
Old 11-14-2017, 11:18 AM   #3
Draayer
Member Number: 8981
It sounds like my best option is to swap the front and rear axles to my 71. How much slower will the 4.09 gearing be compared to the 3.72? Will it hit 60 mph?
Old 11-14-2017, 11:32 AM   #4
FDChappie
FDChappie's Avatar
Member Number: 3742
60 should not be an issue, what size tires to you plan to run?
Old 11-14-2017, 11:37 AM   #5
Draayer
Member Number: 8981
Tires and wheels are stock
Old 11-14-2017, 02:39 PM   #6
1975IH200
1975IH200's Avatar
Member Number: 731
It will be 9% slower at the same engine RPM's.
