Old 03-30-2017, 09:06 AM   #1
BigDave
Member Number: 7936
Question Emptying Gas Tank
I have a 1974 Scout II on which I'm planning to do some body work, so I'd like to disconnect and drop the fuel tank. To do that, I'd like to first drain the tank. This seems like a simple task, but I'm a bit stuck.
is there a 101-level set of instructions somewhere or video on how to safely drain a Scout II fuel tank?
Many thanks,
dave
BigDave is offline   Reply With Quote
Old 03-30-2017, 10:16 AM   #2
Hondo
Hondo's Avatar
Member Number: 4714
Default Re: Emptying Gas Tank
The second time I had to drain mine, I bought a cheapo inline electric fuel pump and just stuck a small hose down in from the filler neck.
Old 03-30-2017, 10:05 PM   #3
int77345
Member Number: 624
I did about the same thing to, cheep fuel pump, power off the battery, and I hooked in to the fuel line at the carb and pumped it about dry
int77345 is offline   Reply With Quote
Old 03-31-2017, 05:41 AM   #4
ihpartsjeff
Administrator & Owner
ihpartsjeff's Avatar
Member Number: 1
Originally Posted by hondo View Post
the second time I had to drain mine, I bought a cheapo inline electric fuel pump and just stuck a small hose down in from the filler neck.
I was going to reply with the same advice. A cheap electric fuel pump works great and afterwards you won't have dragon breath from sucking on a fuel hose.
IH Parts America - Owner
Binder Books
(530)274-1795
Old 03-31-2017, 08:24 AM   #5
FDChappie
FDChappie's Avatar
Member Number: 3742
As a firefighter who has personally had static electricity ignite fuel while being pumped, I'd suggest just leaving it in the tank and raising and lowering the tank with a floor jack. Grounding and conductive hoses is a big deal when pumping fuel.
However if you do choose to siphon the gas a good trick is to use a second short fat hose (1/2 or 5/8ths). Insert both hoses in the tank and seal the neck with a rag. Then blow in the short hose to pressurize the tank and start the siphon.
1974 Scout II 345 T-19
1971 Travelette 392 T-36
Old 03-31-2017, 11:18 AM   #6
jeff campbell
Member Number: 39
Lol, thats a good 1 Jeff !
jeff campbell is offline   Reply With Quote
Old 03-31-2017, 11:20 AM   #7
jeff campbell
Member Number: 39
Originally Posted by fdchappie View Post
as a firefighter who has personally had static electricity ignite fuel while being pumped, I'd suggest just leaving it in the tank and raising and lowering the tank with a floor jack. Grounding and conductive hoses is a big deal when pumping fuel.
Yup it works to ! If you get the neck sealed.gorilla tape !
Old 04-03-2017, 09:35 AM   #8
BigDave
Member Number: 7936
Thanks all!
Tags
drain, fuel tank, siphon
