Old 01-28-2009, 11:00 AM   #1
GK_Slick
GK_Slick's Avatar
Member Number: 574
Default Welders
I am curious if a 240v miller 180 is "big" enough to weld the "c"s from a Dana 44 back onto the axle tubes? Flux core vs. Gas?... Any advice welcome.
Thanks
oops. Guess this should be in the tool talk.
Details:
5/77 GGD SII, 345/727/D20, Holly2v 0-7448, D44 F&R 3.07s, SJ 4"SUA & ssBrkLns, +2"Shkls, RPT eng/trns mnts & steering support plate, DUI diz & LvWr ign., ps, pb, cruise, tilt, a/c, and most factory opts.
GK_Slick is offline   Reply With Quote
Old 01-28-2009, 11:28 AM   #2
Robert Kenney
IHPA Tech Moderator
Robert Kenney's Avatar
Member Number: 543
Default Re: Welders
Yes the 180 is big enough. Don't just do a single pass. Multi- pass or create a full fillet using a zig zag movement. I have a millermatic 130amp/110 volt unit and it would be up to the task preheated.
Always with a gas cover/mig. Flux core is messy and in many cases brittle with cells.
Robert Kenney
Old 01-28-2009, 02:38 PM   #3
GK_Slick
GK_Slick's Avatar
Member Number: 574
Default Re: Welders
Thanks robertk,
as I look into doing this "cut n turn" I get more and more courage to do it myself plus it doesn't help I am froogle and was given my welder as a gift for a birthday. So if I can get a gas bottle and a spool of wire for what it would cost to have someone else weld it then I see that as coming out ahead! Except my skills May not be good enough. If my weld sucks my friend will tell me. At that point I guess I can cut if off and re-do it.
So .035 wire and argon sound good?
Details:
Old 01-28-2009, 03:00 PM   #4
Robert Kenney
IHPA Tech Moderator
Member Number: 543
Default Re: Welders
I would only recomend having some one with "exceptional" welding skills attempt the welding. If you have a problem you May not know it untill it breaks. That could be a life endangering event.
save your money and have a good welder weld it. The small tank will run $100.00 or so from an outfit like airgas or prax air.
The proper cover gas for mig on mild steel using er70 alloy wire is mix 75% co2 + 25% argon.
Robert Kenney
Old 01-28-2009, 07:10 PM   #5
reuben
reuben's Avatar
Member Number: 35
Default Re: Welders
Weld it with flux core will be fine. Flux core wire has something like 60,000 pd. Tensile strength it is more then enough if you know how to weld it correctly, with multiple pass, not 1 giant zig zag pass.
another scout 2 on 1 tons
http://www.thisdysfunctional.org
http://www.norcalscouts.com
reuben is offline   Reply With Quote
Old 01-28-2009, 09:13 PM   #6
username
Member Number: 781
Default Re: Welders
Ditto on the 75-25, works the best. The innershield wire would be fine. It's plenty strong.
Based upon your experience with the welder and the mig process, I would have a reputable welder do the job. You could probably get it done but it would suck if you didn't. The cost of the welds if you do the rest yourself will probably be less than you can get set up to run mig anyways.
Tony
username is offline   Reply With Quote
Old 01-28-2009, 10:06 PM   #7
GK_Slick
GK_Slick's Avatar
Member Number: 574
Default Re: Welders
Hey thanks everyone. I don't have a problem standing on, sitting on or riding on a weld I do but putting my son and/or wife on them is a different matter. Well at least on a 5200+ lb vehicle. At least for now.
Thanks again
Details:
Old 01-29-2009, 07:49 AM   #8
Robert Kenney
IHPA Tech Moderator
Member Number: 543
Default Re: Welders
Originally Posted by reuben View Post
weld it with flux core will be fine. Flux core wire has something like 60,000 pd. Tensile strength it is more then enough if you know how to weld it correctly, with multiple pass, not 1 giant zig zag pass.
I agree fcaw is adequate but it can also be more difficult to the less experienced to create a satisfactory weld. A multi pass weld where the slag is not removed before the next pass can be even worse . I guess it depends on what one considers a satisfactory weld.
Robert Kenney
Old 01-27-2010, 03:12 PM   #9
Rock Tractor
IHPA Tech Moderator
Rock Tractor's Avatar
Member Number: 46
Default Re: Welders
All flux core/nr211 wire has a 70,000 tensile strenght. Pre heating has nothing to do with penatration. Pre heating and post heating is only for control of the cooling process. Yes you can use a 110v welder, but it will not be the proper way to do it. Now for structural steel we use nr232 because it is a lohy wire same as 7018 stick. The 180 will handle the job, but you need to ask yourself, "can the operator/you handle it?".
Just your average Injected 392 Scout II on 60's and 42's with a Wheel Base stretched to 113"
KJ6FOR
Dysfunctional RockCrawlers
NorCal Scouts
DANGER RANGER RACING
Rock Tractor is offline   Reply With Quote
Old 01-27-2010, 08:20 PM   #10
Robert Kenney
IHPA Tech Moderator
Member Number: 543
Default Re: Welders
Wow, you dug up an old post!! Year old in 2 days.
I don't mig anything anymore other then feild repairs.
Robert Kenney
Old 01-27-2010, 11:34 PM   #11
Rock Tractor
IHPA Tech Moderator
Member Number: 46
Default Re: Welders
This was the first time I read this thread and I saw misinformation. We pride ourselves here with facts and not opinion, so I figured I'd post for the folks that read this for tech.
KJ6FOR
NorCal Scouts
