Old 08-26-2018, 07:17 PM   #1
Jimbo75
Member Number: 3972
Default 1975 Scout 2
***SOLD, SOLD SOLD***
Thanks to ALL for your support and continued assistance.
1975 Scout 2 asking $8,500.
Cross posted on CL and Facebook.
https://sfbay.craigslist.org/eby/cto...697530060.html
1975 International Scout 2
Basic Specs.
Engine: 345, 5.7L, V8
Trans: Automatic TF 727
SOA Axle - Rough Country lift springs - About 10" Total
Axles: stock Dana 44's, front has been "cut and turned" for SOA
Brakes: Front Disc, Rear Drum
Tires: 35" TSL Thornbirds + Full Spare (Loose)
Rims: 15" - Chrome - Manufacturer unknown
33 gal. gas tank, aftermarket.
Class 3 receiver hitch, frame mounted.
Has been a multi-year project for me, have listed what I can remember. Essentially performed a frame on restoration. Almost done but not enough time anymore. Should have ALL parts/ items needed to complete.
New/ Completed Items:
Areas of minor rust have been cut out and repaired.
Floor fully coated w/ Herculiner.
Driver quarter and tail light housing replaced.
Rebuilt top end w/ Fel-Pro and painted.
New aluminum radiator, correct for make/model.
6 point roll cage, aftermarket of some kind, backing plates under body, no frame connection.
New gauge kit and panel.
Majority of wiring redone.
Front Seat = 60/40 split bench, serape blanket upholstery.
Rear Seat = Hinged and Folding bench, serape blanket upholstery.
Alpine Stereo, 6 " in front and 6x9" in rear, 8" sub + Amp.
Hardtop fully restored. Insulated, built headliner added LED to front/ back.
New body bushings.
New spring perch and shackle bushings.
Upgraded front shackles / hardware.
Custom front bumper w/ brush guard and winch mount.
Warn M8000 winch, fully mounted but not hardwired. Tested and functional.
Grill Section from 1973.
Needs Finished:
Glove box sectioned for roll cage, door needs to sectioned to fit.
Heater box, switches and cables in place. Untested, condition unknown.
Have shaved side marker lights, body worked in progress.
Weather stripping needs to go back in once paint completed.
Paint: Plan is and was to do all with "rattle cans". Some panels have been completed some still need body work prior to painting.
Head lights and tail lights need to be reconnected.
Needs rear bumper + spare tire carrier. Have some different "builder options", if interested.
Probably much more to list for both sections, will answer questions as best as possible and share additional pics if available.
$8,500
Located in Livermore, CA
File Type: jpg 17C563C2-26F7-4599-B80B-845B1C114C2C.jpg (98.0 KB, 331 views)
File Type: jpg 6EF6C886-29CF-4E7E-B9C3-F0E11DE42DC1.jpg (73.6 KB, 251 views)
Jimbo75 is offline   Reply With Quote
Old 09-16-2018, 07:44 PM   #2
Jimbo75
Member Number: 3972
Default Re: 1975 Scout 2
Price Drop
$8,500.
Old 10-03-2018, 04:49 AM   #3
Jimbo75
Member Number: 3972
Anybody interested in meeting if I bring this up to IHSFR this weekend?
Old 10-03-2018, 07:58 AM   #4
dkminors
dkminors's Avatar
Member Number: 1337
Would be happy to see you up at the Rallye.
There are several of us going up there this weekend from BABS. There may be people up there looking for a new project. Usually about 70 to 100 rigs at the event and people sometimes bring friends who are looking for a rig.
Good luck.
Dan
1975 Scout II 304 4-speed
dkminors is offline   Reply With Quote
Old 10-12-2018, 09:41 AM   #5
Jimbo75
Member Number: 3972
Thanks dkminors.
Never made it to the Rallye, only made it as far as Sacramento. See my thread, "Oil "blow out" = Engine "Mis-Fire" ???". Cross posted here and BP.
If I dont' get results trying to solve my own problem, do you know of a traveling "Scout mechanic" within Bay Area that may be able to help?
Old 10-13-2018, 09:00 AM   #6
dkminors
dkminors's Avatar
Member Number: 1337
There is someone I know of locally who may come to you. Not sure how to reach him. Maybe someone else here knows Keith's contact info.
Where exactly are you located?
Old 10-18-2018, 07:17 AM   #7
Jimbo75
Member Number: 3972
Old 10-18-2018, 12:29 PM   #8
Winchested
Member Number: 9303
Well that's good did you get what you were asking for it?
