Go Back   IH PARTS AMERICA > IH Parts America Area > IH Parts America Product Questions
Old 06-17-2019, 07:37 AM   #1
evanmc
Member Number: 9715
Default Correct temperature sensor for AMC 232?
1971 Scout 800 W/ AMC 232
Which of these temperature sensors are correct for the AMC 232 engine? I just replaced the temp gauge with ISSPRO 100-240, and the unit on the engine now does not seem to have the correct resistance values, and reads much hotter that is the case.
https://www.ihpartsamerica.com/store...RTEMPSNDR.html
Thanks,
-Evan-
evanmc is offline   Reply With Quote
Old 06-17-2019, 08:06 AM   #2
Michael Dimock
IH Parts America Sales Assoc.
Michael Dimock's Avatar
Member Number: 581
Default Re: Correct temperature sensor for AMC 232?
Evan,
If you have the factory gauges, then you will need this sending unit: https://www.ihpartsamerica.com/store/SL407254C1.html
It is 1/4 NPT so if you need 3/8 NPT, then you can purchase a reducer NPT fitting at your local hardware store.
Thanks.
Workin' at IHPA
62 Scout 80, SOA, RS, 54's/63's, 196, T-18, D-18, Waggy 44's, 5.38's, and Zip/Spool.
Michael Dimock is offline   Reply With Quote
Old 06-17-2019, 08:15 AM   #3
evanmc
Member Number: 9715
No, this is not for a stock gauge. This is for an ISSPRO gauge that registers between 100-240. So part ISS-WTRTEMPSNDR would seem to be the correct one for this application.
For that part, there seem to be several thread choices.
-Evan-
Old 06-17-2019, 08:45 AM   #4
ihpartsjeff
Administrator & Owner
ihpartsjeff's Avatar
Member Number: 1
-Evan-
Can you snap a picture of your current temp sending unit? That way we can size what thread size it is and recommend the proper part.
Jeff Ismail
IH Parts America - Owner
Binder Books
(530)274-1795
Old 06-17-2019, 09:28 AM   #5
evanmc
Member Number: 9715
Thanks, please let me know what other measurements you need.
-Evan-
Old 06-17-2019, 10:09 AM   #6
ihpartsjeff
Member Number: 1
Looks like you need the 1/8" NPT size sending unit.
Jeff Ismail
Binder Books
(530)274-1795
